raywilson12
604
raywilson12
Ok guys. How does the belt cover fasten on the side of a 604? Mine been cut and hacked and i plan on making a new one or fixing the old one. anyone have measurement on the cover or pictures of how its supposed to mount? thanks!
Achto
The mounting points are indicated by the white arrows in the picture if you are using the stock Tecumseh engine. The one behind the engine pulley is a bracket bent to reach a threaded hole in the engine.
IMG_0442_JPG_1515d1afa44bb233a9760f46d64f5cef.jpg.611361c0360cda0fff8c85c0dbc40092.jpg
If you decide to make a new one, the corner marked by the yellow arrow is the only square corner on the entire belt guard. I take all of my measurements from this corner. I clamp a strait edge on to the center counsel and measure down to the belt from it, leaving about a 1/4 to 3/8" spacing between the belt and the guard. The bent edges on the top & bottom are 7/8".
Here is an in process pic of one that I made for a custom tractor that I'm working on. I had to make my own guard because I'm using an engine that Wheel Horse has never used.
  • Like 3
  • Excellent 4
raywilson12
Thank you so much @Achto !  This is whats on it right now.  (also ignore the 702. My research failed me lol!) It was hacked to make up for a centrifugal clutch and running boards for 4 yo me lol.
Achto
I think that I may have a belt guard from a 653 that will work on your tractor with the Techy engine. I'll check tonight.
  • Like 3
Achto
I do have a belt guard from a 653, but it is rougher than I thought. If you are still interested in it send me a PM. You could also place an add in the wanted section here, I'm sure some one has one in better shape.
A picture of the front bracket that holds the guard to the engine.IMG_20190402_173414711_HDR-min.jpg.d825c722b5b2478ef5a2899db6992a59.jpg
