Countdown To Christmas!
Evil Archer 300
Uni Drive Drain Plug
Evil Archer 300
Any tips on removing the drain plug. I just purchased a 416-8 and think it would be a good idea to drain the Transaxle.
ebinmaine
Are you talking about the drain plug that is at the very bottom of the transmission? Not the one that is on the side?
If so, I've never seen one stuck because they sit in gear oil.
Appropriate sized allen wrench and try to tighten it just a hair first, then loosen it.
The Tuul Crib
 Here’s a tool I have found to be very handy for this to  particular  thing .
 It is a plumbing tool I picked up at Home Depot a few years back. Fits perfectly on the drain plug
rjg854
It's a faucet seat wrench,  that should supply a lot of leverage.
pfrederi
1/4" allen wrench  clean out teh crud that is in the hole first.
The Tuul Crib
It worked great for me!
peter lena
while you are at it , its probably a good time to replace the shiftier boot, they usually crack and let in moisture, about 9 $  on the net. use silicone grease on shiftier rod for smooth easy install , Pete
