seven
Rear tiller
seven
Does anyone know what size belt is required for the rear mounted tiller off of a charger 12
gwest_ca
I don't know which one you need but the list below should help to determine which one.
Tiller DNA in the order they were produced
1966 tiller model RT-366
[Driven by hydro transmission pulley. Drive belt 1586 replaced by 9714 (HA x 76" or 1/2" x 76")]
1967 tiller model RT-367
[Front drive belt 1586 replaced by 9714 (HA x 76" or 1/2" x 76") Rear drive belt 7358 (4L x 65.95" or 1/2" x 65.95")]
1968-1973 tiller model 7-1211
[Front drive belt for short frame models 867, 875, 876, 87 and 1075 #1576 replaced by 9691 (HA x 70" or 1/2" x 70")
Front drive belt for long frame models #1586 replaced by 9714 (HA x 76" or 1/2" x 76")
Rear drive belt for all #7358 (4L x 65.95" or 1/2" x 65.95")]
1973-1974 tiller model 7-1251
[Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")]
1975 tiller  model 7-1252
1976 tiller model 67-36TL01
1977 tiller model 77-36TL01
1977 tiller model 77-36TL02
1978 tiller model 87-36TL01
1979 tiller model 97-36TL01
1980-1982 tiller model 07-36TL01
1983-1985 tiller model 07-36TL02
1986-1989 tiller model 07-36TL03
1990-1991 tiller model 07-36TL04
[Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")]
1992 tiller model 07-36TL05
1993-2001 2003-2007 tiller model 79370
Garry
  • Similar Content
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • ryobi.warrior
      By ryobi.warrior
      The belt on my Wheel Horse 314-8 mower deck (05-37SC01) appears to be contacting the deck bracket between the spindle pulleys. I am a novice when it comes to Wheel Horse maintenance (at best), but this does not seem correct.
      I recently inherited this Wheel Horse, so I do not know the maintenance history. Unfortunately, the mechanic who previously worked on it was a no-show for a scheduled maintenance visit.
      Any advice on how to address this? Thanks in advance... this seems like a great forum and I'm looking forward to spending time here!
      Photos (please forgive the dirt and grime, I plan to clean it up!): https://imgur.com/a/4PknZuJ
    • JackHorse
      By JackHorse
      Hi Guys, Had a random occurrence this week. Mowing along with my C85 eight speed in 1 low (grass was thick and wet), went to depress clutch and the drive belt jumped off the idler. I've had this tractor 3 years and it's been working great.  The belt itself looks good except the top of it was a bit chewed up in a short section which I believe happened after it came off.  I put the belt back on and continued to mow with no further issue.  Any ideas as to why this would happen or adjustments I might need to make to prevent another incident? Thanks
    • chsteinke44
      By chsteinke44
      i need help finding the right size drive belt for my 212-h wheel horse and the diagram for installing the belt.   i got the tractor from my wifes grampa and cant find the diagram for it or a replacement belt for it.  the id tag is 3212be01  46590
      the belt i need is the motor to transmition
    • DownHome
      By DownHome
      Looking for belt specs for my 855. Need to know which belt I need to attach from motor pulley to mower 36" mower deck. Thx
