perry
got another leaker
perry
need some axle seals & screw on oil filter for my 877. went to parts tree and they say thier no longer available :D . anybody have another source for the seals?. that filter is high $ also once the shipping is added. seems this partstree.com is kinda expensive.
here is what i found:
Toro Consumer 100607 (replaces 5958)
DISCONTINUED Not available
Search results for seal TOR Toro Consumer 6829
Seal-Rubber Not available
Search results for seal TOR Toro Consumer 5959
Seal-Brake Shaft 1/2" I.D. Your price: $12.20
Toro Consumer 79-5270 (replaces 5990)
OIL FILTER ASM Your price: $9.98
Sparky
I like this place.
http://www.rcpw.com/
Mike....
perry
sohars say seals a no longer available also.
nylyon
I checked Stens and those numbers are not listed. Maybe a good auto parts store can find one which would work?
gwest_ca
Chicago Rawhide is now SKF
5958 and 100607 is CR9878 (1" shaft, 1.499" bore, 1.503" OD and .25" wide)
1447 and 5959 is CR4911 (.5" shaft, .688" bore, .691" OD and .094" wide)
Napa can supply these.
Can't find anything on the 6829.
Garry
combatmp29r
Thanks Garry you beat me to the Chicago rawhide chart :D
Kelly
Perry, Let us know if you find some place to get seals, I haven't checked the no.s yet but I think my 1075 probably takes the same ones and I have one leaking also. Thanks Kelly in MI.
combatmp29r
That would be it Karl
perry
thanks guys. ill see what i can come up with on the rawhide # and let you'all know.
