perry 82 #1 Posted January 28, 2008 need some axle seals & screw on oil filter for my 877. went to parts tree and they say thier no longer available . anybody have another source for the seals?. that filter is high $ also once the shipping is added. seems this partstree.com is kinda expensive. here is what i found: Toro Consumer 100607 (replaces 5958) DISCONTINUED Not available Search results for seal TOR Toro Consumer 6829 Seal-Rubber Not available Search results for seal TOR Toro Consumer 5959 Seal-Brake Shaft 1/2" I.D. Your price: $12.20 Toro Consumer 79-5270 (replaces 5990) OIL FILTER ASM Your price: $9.98 Share this post Link to post Share on other sites
Sparky-(Admin) 21,300 #2 Posted January 29, 2008 I like this place. http://www.rcpw.com/ Mike.... Share this post Link to post Share on other sites
perry 82 #3 Posted January 29, 2008 sohars say seals a no longer available also. Share this post Link to post Share on other sites
nylyon-(Admin) 7,259 #4 Posted January 29, 2008 I checked Stens and those numbers are not listed. Maybe a good auto parts store can find one which would work? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,031 #5 Posted January 29, 2008 Chicago Rawhide is now SKF 5958 and 100607 is CR9878 (1" shaft, 1.499" bore, 1.503" OD and .25" wide) 1447 and 5959 is CR4911 (.5" shaft, .688" bore, .691" OD and .094" wide) Napa can supply these. Can't find anything on the 6829. Garry Share this post Link to post Share on other sites
combatmp29r 27 #6 Posted January 29, 2008 Thanks Garry you beat me to the Chicago rawhide chart :D Share this post Link to post Share on other sites
Kelly 1,029 #7 Posted January 29, 2008 Perry, Let us know if you find some place to get seals, I haven't checked the no.s yet but I think my 1075 probably takes the same ones and I have one leaking also. Thanks Kelly in MI. Share this post Link to post Share on other sites
nylyon-(Admin) 7,259 #8 Posted January 29, 2008 Is this the chart you're referring to? http://www2.chicago-rawhide.com/popup_part...okup_457012.htm Looks like one for the links. Share this post Link to post Share on other sites
combatmp29r 27 #9 Posted January 29, 2008 That would be it Karl Share this post Link to post Share on other sites
perry 82 #10 Posted January 30, 2008 thanks guys. ill see what i can come up with on the rawhide # and let you'all know. Share this post Link to post Share on other sites
