kto434 108 #1 Posted March 8, 2019 Is it possible to add hydraulic lift to a Charger 9 (has a Sundstrand tranny)? If so, is it a difficult conversion and any idea of the parts needed and approximate cost. Thanks! Share this post Link to post Share on other sites
pfrederi 17,886 #2 Posted March 8, 2019 Not difficult. You need a cylinder. control valve, some hoses and an implement relief valve (spring and cone valve). cylinder valve and relief check with A-Z tractors in vendors section hoses wheel horse man also in vendors section. 2 Share this post Link to post Share on other sites
daveoman1966 3,762 #3 Posted March 8, 2019 To add Hyd LIFT to the Charger 9, you need LIFT KIT # 8-4111. Here is a schematic of that kit with parts listed...most are no longer available. However, I have those parts marked in RED. I don't have the Hyd Cylinder 6618 (item # 3) or the Bell Crank (item # 1) but the others...yes. Myu direct email is: daveoman@windstream.net. The cylinder 6618 is in this pic as A and B is the replacement for it, which is rebuildable...A is not unless to cut it open. HYD KIT 8-4111.xlsx 2 Share this post Link to post Share on other sites
