Roym
414-8 no lights
Roym
Hello
I recently aquired a 1989 414-8 with 1300 hours  on the meter,  The headlights are not working and there is a dark green wire with a female lead hanging in front of and below the battery compartment coming from the front of the tractor which is not attached to anything. With the length of this wire I cannot see what it could attach to.  I have cleaned all ground connections, installed new 15 amp fuses (they no longer blow when I attempt to turn the lights on at the switch ???), tested the headlights themselves, bypassed the light switch, and installed a grounded led fixture as a taillight where there were reflectors installed with grommets. I am thinking (not being experienced at this) that the ignition switch may be next in line but that hanging wire is driving me a little crazy. Any suggestions ?? Thank you
pfrederi
Welcome to red square.
Wiring diagrams for you r 414-8 are here  click on the tractor picture
WHX??
:WRS:
Is there a way to trace the wire back to it's point of origin.
Guessing you have a multi meter or simple 12v tester is there power on that lead to ground with the headlight and/or light switch in the on positions?
953 nut
:WRS:
If your volt meter and/or hour meter are working with the key in the "ON/RUN" position then the ignition switch and 15 amp fuse are OK. Is there power to and from the light switch?
Roym
Thank you for your responses and the welcome. I have a 12 volt tester and will check power from ignition switch to light switch and from switch to lights as well as the “mystery” wire which I will attempt to track back to its origin.
Roym
Sorry for the delay getting back here but the cold has been unbearable in my unseated shed. I cleaned all grounds and the switch
terminals and wired and grounded a rear light. The rear light worked off the switch but the front lights didn’t so I will replace the wire from the switch to the front lamps and hope they work.
squonk
Make sure your hood is grounded!
Roym
Thanks Mike, I will check that first thing in the am
Roy
Roym
Mike
You were on the money. I replaced the hood to chassis ground and..........lights front and rear! Thank you for the advice. I deeply appreciate your insight and this forum.
Royals
