minotaur57
Spindle assembly on mower deck wasted. No. 104891.
minotaur57
Mower deck - 42MR01  5218.  Spindle assembly - 10489166.  Center pulley - 106847.  Problem #1: Assembly and pulley have wiped into each other and are shot.  Neither are salvageable.  The shaft in the assembly was a 3/4' DD as was the pulley.  I recognize these are NLA and am looking for an OEM in good shape or an alternative.  Problem #2: Having trouble finding blades. Are 3/4" DD blades available?  I believe in you guys and I am sure you will offer appropriate guidance.  Thank you for your help in advance.SAM_1427.JPG.afbff7e051e4846e29e9d42ffbf35131.JPG
The Tuul Crib
Try the classifieds here and put up an ad .
Im sure there is someone who has what you need!
:text-welcomeconfetti:to:rs:!!!
minotaur57
Thank you.  I will do that.
daveoman1966
I have the EXACT spindle assembly and top pulley # 106847...   Here are a few pics.
The lower side of the pulley has a very small chip that I will file smooth to avoid contact with belt.
Top and lower end bearings are good.  Housing  has very little corrosion and is tapped with grease zerk.
Spindle shaft is excellent on DD ends and the pulley fits TIGHT..The blade cup is also on TIGHT.
Send me an off-site email for further details.  my email is:
daveoman@windstream.net
