TR250driver
B-80 Steering Wheel removal
TR250driver
Hey Guys,
Working on the B-80 restoration. How does the steering wheel come off the upper steering shaft? Or should I not go there?  I could leave it on and work around it but then the control panel housing won't remove from the shaft. Thought I would ask before I ruined something.
Thanks,
Darrell
Lee1977
There is a roll pin in the steering wheel and shaft. Some time they can be knocked out. A lot of steering wheel removal depend on the condition of the tractor. If it had been stored inside there is a good chance it can be removed. If it's been out side and there is rust under the center cover I would leave it on and work around it.  That is if the steering wheel is in good shape.
BOB ELLISON
Do a search on steering wheel removal.
You'll find a lot on it. They can be almost impossible to get off. I had to remove the whole steering shaft with the hood stand Assembly.
That's what the steering shaft goes through. I couldn't get mine off so this is how I did mine.
Edited by BOB ELLISON
953 nut
:WRS:
To remove  the roll pin you will need a GOOD QUALITY pin punch. Use PB Blaster or your preference of penetrating oil in preparation for the removal. Park the tractor where you can brace the steering shaft against a wall or tree with a 2 X 4 wedged between them so the shaft won't rebound when you strike the punch.
Once the pin is out you can use a bearing splitter puller to remove the wheel without causing damage. Many auro parts stores will lend or rent you the puller.
Image result for bearing splitter
Achto
If the roll pin absolutely refuses to come out with a roll pin punch, you can drill it out. The only drill bit that will work for this is a 1/4" carbide tip drill bit any other bit will just be destroyed by the roll pin.
TR250driver
Ok thanks.  I have the wheel and shaft on the bench. The wheel is in good shape but once the center cap is removed I can see that it is rusted real bad in there so I am just going to leave it be.
ET160
I remember I had a real time taking my steering wheel off.  I used a puller and penetrating oil.
Hacksawhero123
I split mine with a grinder. The wheel was in bad shape, anyway. I replaced it with a generic Grant wheel using a dune buggy quick connect. Good luck.
Mark
