gt14rider
Gt14 90-2062
daveoman1966
Mind did not have any such 'scratch' in the block.  If you are concerned about it, I'd mix a tiny bit of JB WELD and fill the scratch...CAREFULLY sand it smooth and move on.  CAUTION..don't let the needle bearings drop out...mine did.  Find a ratchet socket or two to hold them in place while working.  ps...the is NOT a gasket or O-ring for this, although it looks like one is missing.
Did you also make a LOCATOR mark before taking off the gear cap???
gt14rider
Does anyone know where to get the copper washers for the  pump bolts, and the small orings, what dash #
Edited by gt14rider
daveoman1966
You will have to buy some COPPER SEALS at NAPA or maybe Fastenal....that's what I did.  buy 6 or more, just a little bit over OD then turn them down to correct OD.  I put 6 of them on a 1/4" bolt ...tighten them with a nut, then put bolt in pistol grip drill to turn rapidly on a file that is clamped in my bench vise.  aka...poor man's lathe.
I MAY have a set of O-rings in shop...willl be back in am to advise...
Edited by daveoman1966
gt14rider
Thanks, I have an assortment of copper  washers, with too big of o.d. didn't  think of the drill to turn them down.  As for the orings, went to a hydraulics shop, said I could  use round orings for the pump, but if I can get the right ones I would rather.
gt14rider
So here is the washers
gt14rider
So this is how the the trans filter was pulled out,
Does the filter come apart?
oldredrider
That filter is toast. And not good toast. Replace it or die! :ROTF:
gt14rider
Cleaning up pump, chased  all the threads,  replaced all orings , reassembled  forward and reverse valves, replacing bearings and seals
gt14rider
Hay it's  just bent in the middle,    you got one you want to sell
oldredrider
Yes I do! Send me a PM.
WildmanC120
Where do you get the springs and orings for the forward and reverse valves?  I have a GT14 that drives but its really weak.  Was thinking about trying that 1st.
gt14rider
Didn't  replace the  springs ,  thay are nla,  you might  try  (LJ  Fluid Power, of Michigan)  but  you might look for a donor pump
gt14rider
As far as the orings, pfrederi helped with some, went to a local hydraulics shop for others and still looking for orings for behind pump,
If you go to a good parts store or hydraulics shop they can find using  Dash # , here is what I used for the gt14
Dash#  113,                2ea
              116,                1ea
              026,                2ea
              018,                2ea
              017,                2ea
              118,                2ea
              015,                2ea
              905,                7ea
              113                  backer ring.   1ea
Will post other orings when I get them,
Back of oil pump orings
              011 sq cut    4ea
              021 sq cut    2ea
Sundstrand manual has break down of pump, you can download  from this site.
Edited by gt14rider
Update
gt14rider
My next problem is spring for rev check valve,  part # 7753, can anybody point me in the right direction to buy one.
gt14rider
Thank you sir, springs on ordered. :D
gt14rider
Got another one for ya, where to buy round snap ring on pump shaft.
I may call LJ Fluid power on Monday, or try stopping  by granger
Ordered bearings , I boggerd up one , so would like new snap rings if I can
Edited by gt14rider
gt14rider
Hay got some stuff done on the bathroom, and t
ranny.
Put in bearings on trunnion shaft and input shaft, installed seals skf 6757, don't seem to sit flush, if you put on oring and triangle spacer its flush, small side same, but seal has two lips, the outer one just sticks out enough,  (pics) any thoughts
gt14rider
More pics
Edited by gt14rider
Wrong seals
pfrederi
Hydro gears didn't use seals they used O rings.
The piston to piston used a seal WH#103461  CR 6763 which is thinner than what you have
gt14rider
Aldons  gt14 restomod showed this seal skf 6757
So thinking I need 6763.  Or ya think with oring it'll  seal tight,  with cam block and ser# plates
gt14rider
Got the right seal, thanks Paul for proper spec's on seal
gt14rider
Well got some more parts, put trunnion shafts in and put spacer and snap ring back in, now it's not centered, :ranting: what am I doing wrong,  tried six ways to Sunday no luck
gt14rider
Moving on, replaced bearings on out put shaft, installed pump housing and gears,assembly lube, talked to LJ at LJ Power, said to put blue lock tight between pump housing, torqued bolts, put oil pump with new orings and copper washers . Got a parts box started
gt14rider
Figured it out housing upside down, dam could have sworn fins on top, checked my other transportation flat on top, now all lines up. Only thing didn't mark or take pic of
