MadScientist
75' c-120 snowblower lift assist
MadScientist
Hi all,
i am looking for a diagram on how to mount the lift assist spring on a 75' c-120. i have looked around and cannot seem to find one. i have tried to mount it on the main crossbeam located near the end of the lift rod and doesn't seem to offer any assistance. After working with that snowblower for and hour becomes quite difficult. i am also wondering if anyone has ever done an effective mounting of an electric wench as a means of lift? Thanks in advance for any help you could offer. CA-120 special model # 133619
Eric
Edited by MadScientist
added model number
WildmanC120
Flag should go in the 3rd hole up in the rock shaft.  The spring will go from the tab on the flag forward to the rod that runs across the tractor that the front of the foot plates mount to.
MadScientist
Ok, Thank you. i have it in the bottom most hole, I will move it up two. there is an eye bolt on the flag and I assume the the other end of the spring connects there for tension adjustment?
gwest_ca
Garry
USHorse
And just as WildmanC120 said, use the 3rd hole on the rick shaft.  I was using the second one and kept shearing cotter pins
peter lena
hello mad scientist, I made this up to eliminate the same problem on my 312-8 , I combined it with a chute control arm knob that I added. both of them have proven to be a great help with snow thrower use. I think that the close relation to thrower with spring lift just eliminates the issue. I used car hood springs , cheap and easy to find, taper grind end of chute control rod, use 3/8x16 die nut , knob at local hardware store. good luck with it, pete
WildmanC120
Yes eye bolt on the flag where the hole faces forward on tractor.  You can use a 1" or the like exhaust clamp to attach the other end of the spring to that cross bar.
I was using the 2nd hole for awhile on mine and couldn't figure out why it was still so heavy.  I never realized there was a 3rd hole.  It's a bit of a pain to get the clip in it but it can be done.  I put the blower on my C-161 with hydro lift now so it makes life much easier.
  • Similar Content
    • HyperPete
      By HyperPete
      JD LX-178 with Kawasaki 2 cyl water cooled engine.
      Great shape except for the front hood.  Cracks have been patched, and hinges on the hood itself are broken.  Hood sits fine, just does not open & close properly
      NO DECK!
      Includes (4) John Deere suitcase weights, a John Deere "maintenance kit", and rear chains.
      Well maintained.  Snow blower presently not mounted.
    • dave who poos
      By dave who poos
      Hello!
      I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
      He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
      My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
    • mmmmmdonuts
      By mmmmmdonuts
      Tall Chute single stage snowblower. Has worm drive chute control. Has lift rod as well. Chute is currently detected for storage.
    • jebeli
      By jebeli
      Lets make a deal. The whole collection for $3000 or one tractor and half the items listed below for $1500.
      I am moving to town so am willing to do a partial trade for a wheelhorse more approproiate for a suburban lot- lawn ranger, surburban models, bcs walking tractor, other?
      I could possibly deliver or meet half-way or ship.
      Both tractors run great and are in good working order. Second owner of both machines. I work with these machines everyday so they are not perfect but are, in my opinion, in excellent shape.
      42in high-shoot snow blower
      42 in rear discharge deck
      Snow blade
      Front mount deck hanger with 42in side discharge deck
      30in lawn seeder
      Brinly single bottom plow with cleavis or sleeve hitch
      50in grader blade
      Extra transmission
      36in rear tiller - leaks a little
      Full set of tire chains for each tractor
      Various body pieces
      7.5 cubic ft pull behind cart - may need tires
      Extra set of rims
      All required belts, pullys, brackets, manuals, too much to list.
    • 83mercedes
      By 83mercedes
      i am going to be getting a 518h with a snow blower as i am new to having a snow blower one thing i noticed was that the chains have a fair amount of play how much is to much ,and would like  a service manual or a manual that would give me these facts,thanks
