hcminis 1,801 #1 Posted February 14, 2019 Every weekend so far in 2019 I've hauled home a Horse. Turning out to be a great year so far. Last weekend I snagged this poor tractor that someone has added custom features to. Believe it is a 702 that someone cut the tank and hood. Plus installed a Briggs and Stratton motor. Well have been wanting to put a 520-H forward swept axle on a round hood. So...since someone else started butchering the poor girl, figured it would be a good candidate for the axle project. Little adjustments and it was on. Added the wide rear rims and tires also. Next step is to possibly put the gear reduction steering on it. Still need to switch the seat out. But happy how it looks so far 14 Share this post Link to post Share on other sites
stevasaurus 23,857 #2 Posted February 14, 2019 Pretty cool for sure, but it is not a 702. It is a 1963 or 1964 model. The 1962s did not have the star wheel adjustment for the lift. See if there is a decal under the paint on the belt guard. If so, you can lightly rub the decal with Acetone to remove the paint and save the decal. The decal will tell you what horse you have. 1 1 Share this post Link to post Share on other sites
WHNJ701 4,173 #3 Posted February 14, 2019 is that a vertical shaft lawn mower engine mounted horizontal? Share this post Link to post Share on other sites
Mike'sHorseBarn 3,684 #4 Posted February 14, 2019 58 minutes ago, jabelman said: is that a vertical shaft lawn mower engine mounted horizontal? I was wondering the same thing! I think it's just the flywheel cover though. Share this post Link to post Share on other sites
Lee1977 7,800 #5 Posted February 14, 2019 Now it needs duel wheels or 12 x 12 x 26's on 12" wide wheels . Looks a little light in the rear. Share this post Link to post Share on other sites
953 nut 69,745 #6 Posted February 14, 2019 4 hours ago, stevasaurus said: The 1962s did not have the star wheel adjustment for the lift. Two bolts and a drill is all they needed to add it. 4 hours ago, stevasaurus said: The decal will tell you what horse you have. The decal will tell you what the belt guard was on. 4 hours ago, hcminis said: Next step is to possibly put the gear reduction steering on it. Why! Is it that hard to steer? I love the look you are developing there. 51 minutes ago, Lee1977 said: Now it needs duel wheels or 12 x 12 x 26's on 12" wide wheels . Looks a little light in the rear. With the Wide Clide front end you NEED dual rear tires! Share this post Link to post Share on other sites
hcminis 1,801 #7 Posted February 15, 2019 18 hours ago, stevasaurus said: Pretty cool for sure, but it is not a 702. It is a 1963 or 1964 model. The 1962s did not have the star wheel adjustment for the lift. See if there is a decal under the paint on the belt guard. If so, you can lightly rub the decal with Acetone to remove the paint and save the decal. The decal will tell you what horse you have. Thanks Steve....it is a cobbled up mess so who knows what it actually started as. This is the first Wheel Horse that I have actually customized. Not one to do any customizing as I like the original look. But, as mentioned, it is already a Frankenstein. 2 Share this post Link to post Share on other sites
hcminis 1,801 #8 Posted February 15, 2019 17 hours ago, jabelman said: is that a vertical shaft lawn mower engine mounted horizontal? Pretty sure it is a vertical shaft cover on a horizontal shaft motor. Share this post Link to post Share on other sites
SPINJIM 1,997 #9 Posted February 15, 2019 Looks like a hybrid between a 702, and 604, and a 520. That's what happens when you keep male and female Horses together in the same barn. But I still like it. 1 2 Share this post Link to post Share on other sites
953 nut 69,745 #10 Posted February 15, 2019 7 hours ago, hcminis said: Pretty sure it is a vertical shaft cover on a horizontal shaft motor. If it is a vertical shaft engine you will find out soon! 1 Share this post Link to post Share on other sites
hcminis 1,801 #11 Posted February 17, 2019 On 2/15/2019 at 2:32 PM, 953 nut said: If it is a vertical shaft engine you will find out soon! Previous owner used if for several years for plowing snow. Know it isn't a vertical shaft 1 Share this post Link to post Share on other sites
AMC RULES 37,260 #12 Posted February 17, 2019 Looks like a fun little to play with. Share this post Link to post Share on other sites
HorseWhisperer 243 #13 Posted July 28, 2024 It looks like a daddy long leg spider! Share this post Link to post Share on other sites
