Badges and engine don’t match ID Plate
By
LengerichKA88, in Wheel Horse Tractors
Similar Content
By LengerichKA88
Hey all!!
Its been quite some time since I’ve been able catch my breath, let alone get on here long enough to post anything.
Ive been extremely busy at work since the holiday season. (Big Box Distribution Center). Especially with everything going on currently, we’ve been working overtime and pushing production like crazy to restock the stores we service. I have, in a matter of months, worked my self to a merit position that is essentially an assistant managers position.
Personally, life has been just as hectic. My wife’s grandmother moved in with us a few weeks ago, right before the COVID 19 really hit here in the states. She’s the one that had a stroke, and there have been several other incidents that have left her unable to live alone. Today, her sister and roommate for 15 years, passed away, as she had been having health issues as well and was hospitalized herself. My grandmother had a heart attack several weeks ago that led to the discovery of four major blockages, none less than 88%. She is (thank goodness) currently home and still “Fat and sassy”. But, things have been stressful to say the least.
We found out Sunday that there was another employee in the warehouse that had tested positive. I called in last night to kinda weigh my options, as I now have two elderly, susceptible people, as well as two toddlers, in my house. A coworker texted me and told me that last night (I work 6p-6a) they were told two more had been quarantined. So, today I took a 30 day unpaid leave of absence! I’m not going to be responsible for killing my father in law or my grandmother in law.
In an attempt to keep things light hearted and happy around here, I’m treating it as a vacation. Might as well right!? Haha.
The man cub has expressed interest in working on the tractors, so this week sometime I think we might attempt to tackle the rewiring of the Charger that I abandoned in the fall.
I also started another project with the neighbor using my grandpas old Snapper. We’re going to make it into a one man Mule/Dunebuggy mobile.
This is something that’s going to be long and slow, as the plan is to salvage and repurpose as much as possible. We’ve already stripped it down and gutted it for the most part, so now we HAVE to do something with it.
For the next month or so, I should be around more. I’ve missed having the time to just sit and read and interact with you all, but I’m looking forward to hearing from you guys on my “vacation”.
Here’s some pics of where we’re at on the Snapper (NTBD) project.
we’re going to extend it out the back a bit, simply for a bit of storage. The plan is to use 40mm ammo cans as fender tool boxes. Haven’t decided how to power it yet, but was thinking about going with a chain driven set up for simplicity. We’d like to keep the handle bars and throw a twist throttle on it.
Of course this could all change over the course of the build 🤷🏻♂️😂
@ebinmaine
@pullstart
By LengerichKA88
Hello all! Long time no see, I’ve started a new job that’s has me pretty much wiped out, so I haven’t been on or tinkered much lately. Today I wasn’t too sore to get motivated to have some “Dad time” so I figured I’d learn how to put the deck on my Charger 9
I don’t know what I’m missing if I’m missing something. The belt is the one that was on the deck when we got it last year, but the deck was off of the tractor, so I’ve never seen how it goes on. At this point I’m just trying to make sure I’ve got everything to connect this deck, and make sure I’ve done what I can on my own properly.
I’d seen that some use a chain linkage instead of the bar or j Rod. I cut a piece of chain to make my own, just to see how it’ll work. So far I have it to where it does, ever so slightly raise the deck, so I need to play around with that some more. Since I seem to be headed in the right direction with that, I figured I’d try the belt routing to see how it goes and I’m now scratching my head.
I’d looked through the files and some posts, but didn’t see what I needed to see to get a good visual. If anyone could help me out with decent pictures, and if possible as close to nine as possible that would be great, but any clear visual one happens to know of would be great too!
Thanks in advance
By LengerichKA88
I liked, but didn’t find an applicable thread, so I made a new post.
We got a 69 Charger 10 last Friday. The brakes don’t really stop it, kinda slows it to an idle speed. Still too fast for the brakes to be engaged. FIL did some reading and it’s apparently the gears that stop the tractor, so now we’re looking at servicing and possible actually doing work on the trans. That’s fine, not a problem, figured we’d get into this eventually, so with the one known issue at hand, how would/have you gone about tackling this trans?
Trying to get voices of experience that might be able to save us a headache or two lol. TIA!
By Builderchris
I need some help. I just purchased 3 garden tractors, plus implements, from a guy on Craigslist and I'm having difficulty identifying one of them. It looks to me like it's a C100, but honestly for all I know it could be a Raider10 or a charger10 just as easily. I'm really not sure. The tag under the dashboard reads, Model T10, Serial # 329650. When I googled Wheel Horse T10 I got nothing. Can one of you great Wheel Horse guru's help me out?
Thanks
Chris
By Deadguy
So, today two more horses followed me home. These critters sure are friendly! Somebody should have warned me that they breed like rabbits! Anyways, the first is a B80 with the 8 speed and a 16hp Kohler. The metal is straight and it runs strong. It does need a governor adjustment and the voltage rectifier needs to be hooked up. The tires look ok, but they are very hard and are starting to crack. The second is a Charger 10 with hydro trans, an 8hp Kohler that smokes a little, and duallies. This tractor needs a new voltage rectifier, one new rear tire, and an engine rebuild or new engine. These tractors came as a package deal with a bunch of parts, including a couple mule drives, a 30-some inch universal snow plow, and a 38" triple blade rear discharge deck. $400 took it all home. How do you think I did?
