artfull dodger 440 #1 Posted February 13, 2019 Hello, can you make up a custom dash decal for my Commando 8. Mine is the one you did the custom Autism Awareness hood/fender decals for. The custom part is the labeling for Choke and the Gen indicator light need to be changed since mine is repowered with a diesel engine. Choke needs to changed to "Intake Heater" and the Gen indicator light labeling needs to be changed to "Preheat" The rest is normal in relation to the key switch and the throttle. Also looking to see if you can use the same font as the "8" that goes below Commando and make the work "Diesel" that will fit in the same place where the "8" was. Thanks Mike and Michele T Share this post Link to post Share on other sites
