dells68 7,499 #1 Posted February 13, 2019 (edited) Well, being the lazy bones I am, I decided to use POR15 gas tank sealant to seal the 2 piece tank on Emory’s 633. I had bought a couple of seals from Lowell at the Big Show, but was afraid I’d break a bolt off. Well after having gas in the tank for a few weeks, it started to leak again. I took a light and looked inside and found the sealant delaminating from the aluminum. I have used it in metal car tanks with no issues and prepped this one by the directions, but it just didn’t seem to adhere to the aluminum. Anybody else had this issue? I did manage to get the tank apart to clean it with breaking only 2 bolts. I drilled them out and retapped them. Any ideas on a good sealant to use on the gasket to add a little more protection against leaks? I can’t think of anything that would resist gas. Edited February 13, 2019 by dells68 3 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #2 Posted February 13, 2019 Indian Head Gasket Sealant...https://www.permatex.com/products/gasketing/gasket-sealants/permatex-indian-head-gasket-shellac-compound/...unless you want something more pliable then we will have dig a bit deeper ... 1 1 Share this post Link to post Share on other sites
ebinmaine 75,740 #3 Posted February 13, 2019 1 hour ago, WVHillbilly520H said: Indian Head Gasket Sealant...https://www.permatex.com/products/gasketing/gasket-sealants/permatex-indian-head-gasket-shellac-compound/...unless you want something more pliable then we will have dig a bit deeper ... I'll second that. That was the first thing I thought of as well. The only disadvantage I've ever known to Indian Head sealant is that if you want to disassemble the parts later on that can be a bit... ummmm..... Challenging. 1 Share this post Link to post Share on other sites
WHNJ701 4,167 #4 Posted February 13, 2019 are the gaskets still available? Share this post Link to post Share on other sites
dells68 7,499 #5 Posted February 13, 2019 10 minutes ago, jabelman said: are the gaskets still available? Yes. @wheelhorseman, Lowell keeps them in stock. Check out his website. Great guy with a lot of really hard to find items. Share this post Link to post Share on other sites
dells68 7,499 #6 Posted February 13, 2019 1 hour ago, WVHillbilly520H said: Indian Head Gasket Sealant...https://www.permatex.com/products/gasketing/gasket-sealants/permatex-indian-head-gasket-shellac-compound/...unless you want something more pliable then we will have dig a bit deeper ... Thanks Jeff! I’ll stop by Advance and pick some up today or tomorrow. 1 Share this post Link to post Share on other sites
Racinbob 12,424 #7 Posted February 13, 2019 I've used a few different brands with good results but the one I like the best is Damon Products Red-Kote. I did another 854 tank with it recently. The key to any of them is preparation. 2 1 Share this post Link to post Share on other sites
moe1965 766 #8 Posted February 13, 2019 I recently used a product called Hi Tack to form a gasket that is gas resistant I also used a product called Red Kote you can find it on eBay to add inside the tank and as a sealant I used the red kote on a two piece aluminum tank on a gravely 5 years ago and still holding strong 3 1 Share this post Link to post Share on other sites
dclarke 4,113 #9 Posted February 13, 2019 I had good luck on an 854 tank using a new gasket sealed on both sides with "Yamabond #4". It's available from the jungle site or a Yamaha dealer. 1 1 Share this post Link to post Share on other sites
AMC RULES 37,250 #10 Posted February 13, 2019 (edited) Denny beat me to it. Edited February 13, 2019 by AMC RULES 2 Share this post Link to post Share on other sites
PeacemakerJack 10,837 #11 Posted February 13, 2019 I’m glad to see this post come up. Caleb’s Comanche tank started leaking right before Christmas and so we will be needing to do this before spring. Basketball will be done next week which hopefully will increase our shop time... 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,367 #13 Posted February 13, 2019 I'm glad this came up. I have a 753 that I have been thinking about replacing the tank gasket just because it's old. It doesn't leak so maybe I'll just live by that old saying.....if it ain't broke, don't fix it. 2 Share this post Link to post Share on other sites
Achto 30,191 #14 Posted February 13, 2019 You could always take the route that @pullstart took with his latest build. Looks like a forever fix to me. 4 1 Share this post Link to post Share on other sites
wallfish 18,786 #15 Posted February 13, 2019 X3 with Yamabond #4. Stands up to gasoline. 1 1 Share this post Link to post Share on other sites
formariz 12,352 #16 Posted February 13, 2019 Interesting thread. We have replaced gasket on the 753 here without any sealant, and it has been over two years totally bone dry with no leaks. 1 Share this post Link to post Share on other sites
dells68 7,499 #17 Posted February 13, 2019 Thanks for the help guys! I lined a 754 tank at the same time, but may have to do the same to it. I almost think the POR15 was a bad batch or maybe had been frozen. I loved it for use in my VWs, this was a different experience. I’ll post some pics when I get things buttoned up. Might be this weekend before I get a chance. 2 Share this post Link to post Share on other sites
oliver2-44 11,061 #18 Posted February 14, 2019 Aviation Permatex. My Dad used it on small aircraft and since it was in the shop we used it on farm equipment and autos, and everything. Once you smell this stuff you will never forget the smell. No it's not terrible, just very identifiable. 2 Share this post Link to post Share on other sites
