LengerichKA88 1,883 #1 Posted February 9, 2019 (edited) Is there a way to put a hydro, in my case a Charger 10, in neutral so that it can be pushed around the shop? I’m able to do this with our short frame, which is nice if I only need it a foot or two out of the way, but if I need to move the Charger I have to get on it. Was wondering if theres a tip or trick that I didn’t know about. If not no biggie, but you guys would be the ones to know. TIA. Edited February 9, 2019 by KyleLengerich Share this post Link to post Share on other sites
Ed Kennell 38,681 #2 Posted February 9, 2019 The Sundstrand hydros have a tow valve that needs to be opened to allow the tractors to be moved. They should only be pushed slowly by hand. The hydro must be engaged to release the parking brake on some models. The early hydros (875) had the valve at the upper left rear as a hex nut. Later it was a petcock on top left , and later, it was a slotted screw at the left front of the hydro. The Eatons have no tow valve. The 700 can not be moved but the 1100 can be moved slowly by hand. 2 3 Share this post Link to post Share on other sites
daveoman1966 3,762 #3 Posted February 9, 2019 Give this valve 1/4 turn... 3 2 Share this post Link to post Share on other sites
LengerichKA88 1,883 #4 Posted February 9, 2019 I had a feeling that I would need to open/turn that, but didn’t want to until I knew for sure. Thank you gentlemen! 3 Share this post Link to post Share on other sites
cazngz 19 #5 Posted February 16, 2019 On 2/9/2019 at 1:51 PM, LengerichKA88 said: I had a feeling that I would need to open/turn that, but didn’t want to until I knew for sure. Thank you gentlemen! Just a note.. mine was a petcock type and was extremely hard to move. I kept spraying PB Blaster on it until I could tap it with a hammer slightlly to move it a tad, then back and forth slowly. Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #6 Posted February 16, 2019 On 2/9/2019 at 1:24 PM, Ed Kennell said: The Eatons have no tow valve. The 700 can not be moved but the 1100 can be moved slowly by hand. With the exception of the xi series Eaton 1100 has HI/LO ranges plus nuetral, that would have awesome on a classic 520H. 2 Share this post Link to post Share on other sites
oldredrider 2,549 #7 Posted February 16, 2019 To add to this, turn tow valve 180° to open or close on the Charger. It does not "unscrew" like the later models. 1 Share this post Link to post Share on other sites
Ed Kennell 38,681 #8 Posted February 16, 2019 4 minutes ago, oldredrider said: To add to this, turn tow valve 180° to open or close on the Charger. It does not "unscrew" like the later models. Good point Paul. Actually you turn it 90 degrees to open or close it. Share this post Link to post Share on other sites
cazngz 19 #9 Posted February 17, 2019 46 minutes ago, Ed Kennell said: Good point Paul. Actually you turn it 90 degrees to open or close it. Well, I was with you guys until I saw the 90 degree part. Soo.. does the valve actually turn 180 degrees ( I hope so cause mine does ) or is it you only need to turn it 90 degrees to push it and then another 90 for the tractor to run normally ? My valve moves from 12 o'clock to 6 o'clock. I've only pushed it so far. Share this post Link to post Share on other sites
Ed Kennell 38,681 #10 Posted February 17, 2019 It is a ball valve that is open for towing when the handle is front to back. You can turn it 90 degrees CW or CCW to close it for driving. Share this post Link to post Share on other sites
cazngz 19 #11 Posted February 17, 2019 11 hours ago, Ed Kennell said: It is a ball valve that is open for towing when the handle is front to back. You can turn it 90 degrees CW or CCW to close it for driving. Sooo..... why can I turn mine 180 degrees in one direction ? Like I said, from 12 o'clock to 6 o'clock. I've never had a ball valve turn 180 degrees before. Is there something wrong with it ? It definitely locks at the 12 and 6 positions. Share this post Link to post Share on other sites
Ed Kennell 38,681 #12 Posted February 17, 2019 No, there is nothing wrong with your valve. Share this post Link to post Share on other sites
Pullstart 63,097 #13 Posted February 17, 2019 23 minutes ago, cazngz said: Sooo..... why can I turn mine 180 degrees in one direction ? Like I said, from 12 o'clock to 6 o'clock. I've never had a ball valve turn 180 degrees before. Is there something wrong with it ? It definitely locks at the 12 and 6 positions. Most ball valves in plumbing have a stop built in to the handle. Bend that stop out of the way, it’ll spin like a clock. Share this post Link to post Share on other sites
daveoman1966 3,762 #14 Posted February 17, 2019 That TOW VALVE removed looks like this. Use a crescent wrench to remove and clean it up. 1 Share this post Link to post Share on other sites
cazngz 19 #15 Posted February 17, 2019 34 minutes ago, pullstart said: Most ball valves in plumbing have a stop built in to the handle. Bend that stop out of the way, it’ll spin like a clock. Share this post Link to post Share on other sites
cazngz 19 #16 Posted February 17, 2019 4 minutes ago, daveoman1966 said: That TOW VALVE removed looks like this. Use a crescent wrench to remove and clean it up. That's some great photos and explanation. Becomes much easier to understand w/ photos. Thumbs up 1 Share this post Link to post Share on other sites
