ebinmaine 68,807 #1 Posted February 8, 2019 I'm trying to figure out where the brackets and rods and nuts and bolts and springs and cables and everything go. Basically I can't figure out which thingamabob goes to which whatchamacallit. I took pictures but the ones I have are not showing me what I need to know. Probably should have had Trina take the pictures? Also, how do you adjust/set the governor? 1 Share this post Link to post Share on other sites
Wishin4a416 2,191 #2 Posted February 8, 2019 (edited) Post # 105 in my restore thread Eb. maybe you can blow it up. Edited February 8, 2019 by Wishin4a416 Share this post Link to post Share on other sites
Wishin4a416 2,191 #3 Posted February 8, 2019 Oops. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,338 #4 Posted February 8, 2019 17 minutes ago, ebinmaine said: I'm trying to figure out where the brackets and rods and nuts and bolts and springs and cables and everything go. Basically I can't figure out which thingamabob goes to which whatchamacallit. I took pictures but the ones I have are not showing me what I need to know. Probably should have had Trina take the pictures? Also, how do you adjust/set the governor? We need pictures cuz!!! 1 Share this post Link to post Share on other sites
ebinmaine 68,807 #5 Posted February 8, 2019 @Wishin4a416 Thanks!!! I think those will work. Now about setting the governor... Share this post Link to post Share on other sites
daveoman1966 3,762 #6 Posted February 8, 2019 This is a B-100 with 10hp Kohler...linkages are same as a C-160... 3 1 1 Share this post Link to post Share on other sites
JoeM 7,874 #7 Posted February 8, 2019 EB I always set the governor shaft to be wide open and the carburetor to be the same. (I take the connection / sensitivity spring off while adjusting). I loosen the bolt/nut on the L shaped link, enough that it will move with a little resistance and grab the governor shaft with vice grips and turn it to wide open with the carb link held wide open, snug up the bolt. My thought has been when the governor goes wide open the carb is at full throttle. Hope this helps. 2 Share this post Link to post Share on other sites
ebinmaine 68,807 #8 Posted February 8, 2019 3 hours ago, daveoman1966 said: linkages Excellent Dave. Thanks. You also showed me a couple other things I was going to ask about. 1 hour ago, OILUJ52 said: governor ...... Hope this helps. Also excellent! Thanks Joe! Share this post Link to post Share on other sites
