ebinmaine
What type bulk spark plug wire to buy?
ebinmaine
I know there are different types of cores and different sizes and resistor or non resistor.
Some of our engines have points. Some do not. Don't know if it matters?
I would like to buy 10 or 20 feet to have on hand.
The Tuul Crib
Can it be bought by the foot?
Stepney
If you go online you can find the old 7mm Packard spark plug wire in bulk pretty easy. I use it on everything. Inexpensive and well made.
ebinmaine
Yepp
I already have a few plug end and coil and Boots and a few terminals.
WHX??
Yeah NAPA has it in bulk. Mike @squonk was making some for guys at the BS last year he might even know part nos. It's just standard inductive core cable.
Even comes in RED! :lol:
https://www.ebay.com/i/380900662451?chn=ps
WVHillbilly520H
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F123618732597...or...  https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F143102105494...remember the 5 or 7mm is just the insulation so unlike a highly modified drag car you don't really need thick jackets.
squonk
7mm metallic core ignition wire # 734708
pfrederi
copper core for me.  my farm tractors with mags like it and so do the WHs.  I do not use resistor plugs either.  if i interfere with some bodies GPS int their BMW to darn bad.
  • Haha 2
WHX??
Don't lookit me Squonk... I used a piece of 18 ga thermostat wire once in a pinch... :lol:
  • Haha 4
WHX??
Unless you are in one of those polar kotex :thingy: and it's  -30
  • Haha 3
  • Confused 1
WHNJ701
just go to your local garage and ask the mechanic to save a set a decent set of plug wires for you when they change them out on cars.
  • Confused 1
roadapples
You won't find any that are copper wire....
WHX??
No stones to hang on to one while someone is cranking the motor tho :scared-shocked::lol:
  • Haha 2
squonk
Did you use red or commom? :helmet:
  • Haha 2
WVHillbilly520H
:text-offtopic:,I'm hoping I don't need a "kotex" for my :thingy: :ROTF:
  • Haha 6
953 nut
You can pick up this spark plug wire in the 1,000 foot rolls at Tractor Supply!              :ROTF:
  • Haha 8
  • Confused 1
Achto
Even comes in RED!
Common Jim!!! Everyone knows that yellow plug wires make engines go faster. :auto-driving::D
Edited by Achto
  • Haha 4
Sarge
I use either the good grade Beldon or Packard wire - lasts for years and the higher quality ends fit it properly. Don't buy any imported wire, I've actually found gaps in the internal graphite cores several times - which will drive you nuts. I always have spare ends and wire from sets off hot rods around here - easy to make a new coil wire in a pinch. One real key to success - a proper plug wire crimping tool. Best I've found is Dad's old Belden tool - probably 30yrs old now or more, but still works perfectly and rolls those ends over like factory. I had a newer version and loaned it out, not sure who didn't return it but that led to no tools leaving here without me attached to them.
Sarge
WHX??
28 minutes ago, Achto said:
kit will take care of seven engines.
I would get one but then I would have to get six more tractors to put them on! :hilarious:
  • Haha 3
Achto
Buy the 4cyl kit, it cost the same but then you will only need to buy 4 more tractors to but them on. :ROTF:
  • Haha 2
cod
Would any of you if is it possible to replace the spark wires on a Kohler ignition module?  They look like they are epoxied in on the module but if you can get bulk wire, plug connectors and boots, is this something to attempt?
A new Kohler module for a M-18 twin looks to be about $120+/- so perhaps this might be more affordable if you can figure it out.
Thanks - Cod
Howie
I think that type is going to be very hard to get the wire out. May be possible and ignition module could
be damaged. Some of the older coils the wire could be unscrewed and replaced. The post it went on
had like treads on it so new one was twisted into place.
Aftermarket modules may be a lot cheaper.
