Marv 966 #1 Posted February 2, 2019 I have a Singer model 6212C machine. The thread tensioner assembly had been removed at some time. I put it back together and wound up with an extra piece. It does not seem to fit any way I try it. Maybe it doesn't belong. Anyone have one we could compare it too. Marv Share this post Link to post Share on other sites
Sarge 3,464 #2 Posted February 2, 2019 https://www.youtube.com/watch?v=boZUBTFpSL8 Manual - http://www.singerco.com/uploads/download/1286_6202-6212.pdf Service manual - these are copies, so be aware of that but I have had to resort to using them - https://www.sewingpartsonline.com/service-manual-singer-6212-sewing-machine-service-manual.aspx 6202 & 6212 is the same basic machine. I cannot find any parts drawings for that tensioner - you'll have to use the basic model numbers and hunt YouTube and other sources. Seems like the biggest issue with that model series is threading them - pretty easy to get it wrong. Folks get knots in the tensioner and pull the knob off to fix it, which leads to a no-tension condition from bending the shaft. The end of that support shaft is split - you'd have to spread it apart slightly to hold the recess notches inside the knob to make it work again. If I had my hands on it, could probably have it back together in a few minutes - I've worked on a lot of different models. Hope this helps, Sarge Share this post Link to post Share on other sites
Marv 966 #3 Posted February 5, 2019 Thanks for your reply. I had run through that. I can assemble it ok. It is just that there appears to be an extra piece that does not belong in the tensioner. I can' recall if when we got the machine the tensioner came with it disassembled or if it was disassembled after we got it. In any event it is a puzzle. Marv Share this post Link to post Share on other sites
Sarge 3,464 #4 Posted February 6, 2019 What does this extra part look like, anyway? There's a chance it's an internal piece that goes inside the rear, so it would disappear as the tensioner stack is assembled. Sarge Share this post Link to post Share on other sites
