JoeM 7,923 #1 Posted January 28, 2019 When I seen Medowfied's long haul dolly axle made from WH from axles, it made me remember, I have a project out under a tarp that needs finished. I took two old frames butted together, welded, then cut a piece of pipe and connect the steering rods, made a tongue, steering linkage and viola......4 wheel, wheel horse cart. I need to paint it up an install some accessories, try to finish it this spring. 10 9 Share this post Link to post Share on other sites
peter lena 9,087 #2 Posted January 28, 2019 hey , you can't do that, weld frames together and then add heim joints to the steering ? what will people say ? who cares , keep going , good job , pete 1 Share this post Link to post Share on other sites
Lee1977 7,037 #3 Posted January 28, 2019 I like your design. The only thing I would have done different is add a heim joint at the tongue connection. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,338 #4 Posted January 28, 2019 That's areal cool idea! I'll be watching this one!! 1 Share this post Link to post Share on other sites
953 nut 57,864 #5 Posted January 28, 2019 As long as it is the four wheel steering will be handy! Nice job! 1 Share this post Link to post Share on other sites
Ed Kennell 40,464 #6 Posted January 28, 2019 Really interesting wagon. Great idea. I would keep the tongue attached at the front axle as you have it, but cut the tongue and add a vertical pivot in front of the steering link to take care of uneven terrain and make it easier to connect to different height hitches. 1 1 Share this post Link to post Share on other sites
WHGuy413 2,771 #7 Posted January 28, 2019 Neat. I have been wanting to build a 4 wheel wagon myself. Thanks for the visuals. 1 1 Share this post Link to post Share on other sites
squonk 42,516 #8 Posted January 28, 2019 I thought of doing the same thing. Except I was going to use wood and make it look like a hay wagon. Put the extra veggies from the garden on it so it would be a mobile roadside stand. 1 1 Share this post Link to post Share on other sites
JoeM 7,923 #9 Posted January 28, 2019 12 hours ago, Ed Kennell said: I would keep the tongue attached at the front axle as you have it, but cut the tongue and add a vertical pivot in front of the steering link to take care of uneven terrain and make it easier to connect to different height hitches. Yep, there is play in the tongue pin and I used a trailer ball hitch on the front, worked okay in test, but it needs that pivot joint. 5 hours ago, squonk said: I thought of doing the same thing. Except I was going to use wood and make it look like a hay wagon. Put the extra veggies from the garden on it so it would be a mobile roadside stand. This all kind of started out with this pic. I don't think I will be as fancy with the wood but maybe sides and a removal able seat. who knows it's been under the tarp for a year and a half! It's big enough to haul a broken tractor on............but we know with WH's that will never happen. 4 1 1 Share this post Link to post Share on other sites
Chris G 3,334 #10 Posted January 28, 2019 I'm liking this idea. Make a nice flatbed with some removable side racks and it could also serve as a nice firewood trailer. But nice job so far! Share this post Link to post Share on other sites
Ed Kennell 40,464 #11 Posted January 28, 2019 I keep thinking that folding tongue would also make it easier to store. 1 1 Share this post Link to post Share on other sites
WHGuy413 2,771 #12 Posted January 29, 2019 15 hours ago, squonk said: I thought of doing the same thing. Except I was going to use wood and make it look like a hay wagon. Put the extra veggies from the garden on it so it would be a mobile roadside stand. That is my plan also. The kids wanna try to sell veggies this year. Share this post Link to post Share on other sites
ebinmaine 70,702 #13 Posted January 29, 2019 Great build Joe. Love the connected reversing steering. @Chris G my first thought was for fire wood as well. Joe if you have rough terrain there you could build a 360° rotating hitch like I did on my fire wood pole trailer. If not then a trailer ball connection should be fine. 1 Share this post Link to post Share on other sites
cleat 7,017 #14 Posted January 29, 2019 Looks great. I want to see the video of you backing it up. Cleat 1 Share this post Link to post Share on other sites
Sarge 3,464 #15 Posted January 29, 2019 I'd like to do one similar, but of course, a lot heavier frame. Been wanting a convertible flat bed with removable sides and a hydraulic ram for a dump trailer for a long time. All good ideas, like your design, btw. Sarge Share this post Link to post Share on other sites
