Topo 13 #1 Posted January 26, 2019 (edited) Hello , I have a Toro Wheelhorse and the choke cable keeps freezing and not useable, it will not move so how do I fix this? it is a new cable I installed last spring. Thanks Topo Edited January 26, 2019 by Topo Share this post Link to post Share on other sites
The Tuul Crib 7,338 #2 Posted January 26, 2019 (edited) First thing I Would check just to make sure there are no kinks in the cable then check your connections at the carburetor to make sure there are no restrictions. I would spray or run oil down the cable as well to Edited January 26, 2019 by The Tool Crib 2 Share this post Link to post Share on other sites
pfrederi 18,339 #3 Posted January 26, 2019 Borrow the wife's hair dryer and heat the whole cable spray WD 40 on the exposed ends and work it back and forth also find the lowest point and move a bit of the plastic over coat..(lets any water seep out... 2 2 Share this post Link to post Share on other sites
SylvanLakeWH 27,594 #4 Posted January 26, 2019 Hair dryer then WD40 to get the water out and lube it up... 1 Share this post Link to post Share on other sites
WHX?? 50,778 #5 Posted January 26, 2019 I think the guys have you covered so the only thing I can suggest is move to Florida. Yep, as this winter has turned more normal for Missouri, a move south is looking better each passing, freezing day. I just checked yesterday when the temps were warming up to 17 here, it was 53 in New Orleans, 50 in Baton Rouge, 45 in Jackson, Ms,.......Louisiana, Mississippi, or Alabama would be more my choice than Florida, but it would be a few degrees warmer more south you go in that state. 3 1 6 Share this post Link to post Share on other sites
roadapples 6,983 #6 Posted January 26, 2019 (edited) If you ever have the opportunity to pull the cables apart coat the wire with Sil -Glyde silicone grease. No rust, no wash off, no more problems.... This stuff has many uses.... Edited January 26, 2019 by roadapples Speeling 1 2 Share this post Link to post Share on other sites
Achto 28,801 #7 Posted January 26, 2019 Anti seize also works well for this. 1 1 Share this post Link to post Share on other sites
WHX?? 50,778 #8 Posted January 26, 2019 10 minutes ago, Achto said: Anti seize also works well for this. if you don't mind silver fingers! 1 2 Share this post Link to post Share on other sites
CrazyDetroit 7 #9 Posted January 26, 2019 On older wheel horses if you take the air cleaner plate off carb and when you reinstall it one out of 4 screws is shorter. Make sure the screws are in proper spot longer screw will interfere with choke internally. It will rub on the rod holding choke butterfly. 2 2 Share this post Link to post Share on other sites
Spareparts 85 #10 Posted January 26, 2019 10-4 on the short bolt on the air cleaner, have ran into that problem. I worked for a line building const. co. and the big wire pulling rigs had Several big Morse type cables controlling the hyd. functions and they would get stiff. Morse made pump that would slip over the cable with a hose and pump. It would fill the cable with a special lubricating fluid,freed them up. Well why wouldn't a smaller version work on our cables, so with a small hose slipped over the cable and secured with a clamp and the other end slipped over the spout on a hand pump oil can. Well with a couple of pumps and moving the cable in and out it flushed the rust and crap out of the cable and they worked like new. 1 1 Share this post Link to post Share on other sites
ohiofarmer 3,333 #11 Posted January 26, 2019 I have an ancient cable on a new acquisition that has the plastic covering full of cracks. I just sanded the rest of it off and use penetrating oil ---Deep Creep by Sea Foam company works great-- A little messy, but it got the job done Share this post Link to post Share on other sites
peter lena 9,093 #12 Posted January 26, 2019 I agree with the feedback on this issue, we have all had it at some point. removing the choke cable at carb , so it has a straighter /smoother run will let you get a lubrication drip sooner . I regularly give my cables a drink at each end at full extension. PFREDERI hair drier idea with lube will surely get things going. once you get this freed up, make a regular point of lubing it. you might also find a smoother routing to help out . pete Share this post Link to post Share on other sites
Lee1977 7,044 #13 Posted January 26, 2019 I have seen where take motor cycle cables poke a hole in a plastic baggie put it over the open end of the cable tie it tight, then the add their penetrating oil and hang it up by the bag. Share this post Link to post Share on other sites
bellevillerod 835 #14 Posted January 26, 2019 I had that same problem last year, I went to Kroger and bought a Turkey injector with the screw in needle. Opened it up a little until I could just push the cable cover into it. Then filled the injector and gave it a shot. Takes a minute or two but you will see the oil coming out the knob end of whatever cable your lubing up. I did run into a couple that were really tight fitting but just let it sit overnight up higher than the end and it would work it's way through. For me it was always the choke cable freezing up, that can be aggravating trying to get my plow tractor running. 1 Share this post Link to post Share on other sites
tunahead72 2,518 #15 Posted January 27, 2019 On 1/25/2019 at 10:28 PM, Spareparts said: ... Well why wouldn't a smaller version work on our cables, so with a small hose slipped over the cable and secured with a clamp and the other end slipped over the spout on a hand pump oil can. Well with a couple of pumps and moving the cable in and out it flushed the rust and crap out of the cable and they worked like new. Great ideas everyone! This one in particular caught my attention. There are commercial versions of this idea that clamp around the outside of the cable, so you can attach it without disconnecting the end of the cable. I have one, it works... mmm... just OK, but I may not really have the hang of using it yet. If you can remove the carburetor end of the cable like others have suggested, it sounds like your method will work much better. Share this post Link to post Share on other sites
Topo 13 #16 Posted April 25, 2019 where do I get information on the screws , long vs short . this is in reply to the frozen choke cable.. it works fine when not during cold winter months could it still be screws ? Share this post Link to post Share on other sites
wallfish 17,514 #17 Posted April 26, 2019 6 hours ago, Topo said: where do I get information on the screws , long vs short . this is in reply to the frozen choke cable.. it works fine when not during cold winter months could it still be screws ? No. It's water freezing inside the conduit. Use the advice given in the previous posts. Share this post Link to post Share on other sites
953 nut 57,998 #18 Posted April 26, 2019 11 hours ago, Topo said: works fine when not during cold winter months Share this post Link to post Share on other sites
