Countdown To Christmas!
SimonC
limited slip - raider 10 question
SimonC
Greetings,
so looking at the description of this file:
it says that this is a limited slip.  I'm not an expert, but how does the limited slip in this trans work without two planetary ?
thanks
Simon
pfrederi
item #22 part number 7235 spring cylindrical is what makes it work.  With age that spring can get weak or break  then it acts like a typical open differential
  • Excellent 4
SimonC
thank you sir !
SimonC
are those still available .. not sure it's worth it, but curious.
thanks
ebinmaine
Simon, take a look at this thread. Scroll down to the first video which shows Steve putting the differential back together and you'll see the spring that Paul, above, is talking about.
Achto
:text-yeahthat:
SimonC
how effective would you guys say this type of "limited slip" is ?
pfrederi
They are not lockers but they are in my opinion a huge improvement over open differentials for snow duty.  all my snow horses are the hydro version with the spring.  They impress me with how much they can push with both rear wheel spinning at once.
SimonC
I guess when actually pushing snow (instead of throwing it), every bit of traction must help.
so far I am quite sad about the performance of the 1 stage snow throwing capability on mine .. (short neck).  as soon as snow is a tad wet it becomes useless ..
The Tuul Crib
I just put back together a 5060 trans was was very easy except for the little tiny detent balls that I had to chase around the shop s few times ! That is a great video that stevasuares made! Many thanx to Steve o!!
Ed Kennell
Yes, the single stages tend to clog in the wet snow.      One thing I have found, If you can keep the ground speed adjusted to keep the auger full there is less chance of clogging.
The snow in the auger is actually pushing the snow up the chute and if the auger is empty, the snow left in the chute quickly freezes.
This is one of the reasons I only use hydro tractors.   No stopping and starting to change ground speed.
daveoman1966
Spray the chute / auger with PAM or some other non-stick spray.  ALSO....keep the rpm at or near 3/4 throttle...or more.
JoeM
Anyone spray lube in the chutes or maybe use EZ-slide paint? Might UHMW liner help?
Just thinking.
Just seen Dave's pam comment come in.
JoeM
Question about limited slip. Will that ring work in an 8 pinion axle?
pfrederi
No.   Search there have been several threads about this
  • Sad 1
pfrederi
I have a lot of WHs...I also have a lot of area to clear in the winter.  i have used gear drives.  Experience has taught me there is no better unit for snow removal than a hydro for both plowing and blowing.  i used to use  a 40hp Case DC3 to rearrange snow flakes..  now only Charger 12s and an Electro16 with a single stage short shoot.  Even the slushy mess from last week end was handled by them with ease.  It does not shoot the snow 30 ft in the air like the 2 stages but as long as it will move it beyond the driveway that is good enough for me, I am not trying to impress the neighbors.  also I live on a hill that is windy.  Blowing the snow high in the air is dumb idea for me.
Ed is right the ability to fine tune the speed on a single stage eating snow is important and when it comes to plowing the quick reversals and high speed reverse of a hydro are a good thing.
JoeM
Found that thread, interesting. Looks like that extra gear gives that spring enough traction. Odd, but you proved it! Nice test.
Achto
I use my Raider 12 to pull a mold board plow. The limited slip works great for this job. Even in clay that is a little too wet, it will pull through with little to no trouble.
Edited by Achto
