44” 2-Stage Snowblower Impeller Repair
By
r1jakecfd, in Implements and Attachments
Similar Content
By B J
Nice 520H with 60 inch deck, 44 inch snowblower, winter cab, 42 inch blade although the tractor has the brackets on the back axle the blade doesn't have the extension. Also have the deflector for the mower discharge and a set of tire chains that may fit the tractor. 735 hours. Please text for more pictures
By BaySide1
Hey Guys,
Doing some Maintenance on my 2 Stage snowblower ID # 0644SC01 60442 Ser# 9317
Problem # 1
Last winter Noticed that the Drive Pully on the Blower was wabbling
This spring when I took the belt off I noticed that the Keyway on the spindle and pulley was worn.
The Key ways actually rounded
The set screw in the pully to spindle was missing.
So, what is the easy/cheap fix that will solve this issue
Thinking of mig welding the pulley to the spindle.
How Stupid is that idea?
Problem #2
The scraper Blade is well worn. Should I try to find a new piece or weld something to it?
What would you guys do?
Thanks In Advance for taking the time to Respond,
Best Regards,
Kevin B
