meadowfield
Floating bogie trailer
Blackhood Bill
Very nice & very nice welds. This ought to be interesting to see finished trailer!
WVHillbilly520H
:confusion-confused: Hhhmmm, Excellent,  I have a couple axles laying around thanks for the idea,  Jeff.
Chris G
Great idea!
953 nut
:text-coolphotos:                  Outstanding, you have great ground clearance too.
peter lena
meadowfield, outstanding work detail and ideas on that set up ! between the range of motion and the quality of the weld strength , that trailer or whatever you plan for this frame will move and function with solid ,smooth ,effortless pull on the tractor. your ideas are a testament to your work, great stuff, pete
ebinmaine
Now that would be some kind of Handy here on the Mountainside. Super rough ground.
Looking forward to seeing what you put for a body on it.
meadowfield
Thanks guys, plan is to add a sprung drawbar and hydraulic tipping body. Plan A is manual hydraulic tip, plan B is to use the hydraulics on bendy...
Edited by meadowfield
wallfish
Good idea! Nice use of WH parts for the build. There's not very many things that haven't been done yet but think this is a new one.
lynnmor
Welding steel to cast iron can be tricky, can you tell us what rod you used?
meadowfield
I don't think the axles are cast iron. They possibly have enough carbon to be steel, I used mild steel mig wire to weld.
The Tuul Crib
I myself thought you would have used
nickle rod
wallfish
Cast steel, I used regular rods on that stuff too, 7018.
The Tuul Crib
Being the use these axle are if they were cast iron that would wear out quicker. That would make sense they would have more carbon.
Stormin
 I like it, Mark. I intend, hopefully, to build a twin axle tipper. Need to get a round to it one day.
Herder
3B1E8B3D-C13F-44E4-8C1D-89FFC576AB95.jpeg.db753808d492d169becba09bed48c3fe.jpegAwesome build!  The sheep like it too.
  • Haha 2
ebinmaine
2 hours ago, meadowfield said:
sprung drawbar
What's the particular purpose of that?
AWESOME build !!!
meadowfield
AWESOME build !!!
The trailer is heavy, probably 150-200lbs empty. Full it probably weighs 1000+
I’ve deliberately put 80% of the weight on the rear end, which still leaves a lot of potential weight on the tractor hitch. When you go over the big bumps it’s a lot of force on the rear hitch and the springs take out that energy....
  • Excellent 2
meadowfield
They were rather inquisitive!
  • Haha 1
ebinmaine
Ooooooooooo....
I LIKE that!!
peter lena
your work is reflective of a  grunt , that earned his experience on the line, great to see that , your experience and insight ,is light years out there , your welding detail alone sets you apart. great to have you  on the site, pete
  • Heart 1
meadowfield
For those wanting to see it in action, here's a short video
  • Like 4
  • Excellent 2
  • Heart 1
Herder
That thing is pretty dam sweet :handgestures-thumbupright:  I like it.
peter lena
the strength and set up of that frame is a delight to watch , pete
