BMW1
D200 Transaxle Parking Brake Pawl
BMW1
We are putting this transaxle back together and noticed the parking brake pawl seems to be in bad shape.
The part is NLA but someone said it could be mig welded and filed.
I have never seen what it should look like. Is there supposed to be a "notch" in the pawls or should the weld be built up and then filed so there is no "notch"?
daveoman1966
This is what happens when the parking brake is engaged when the tractor is still moving.  This part is also NLA from Toro/WH.  Take it to a PROFESSIONAL welder and build up the 3 teeth,, restoring them to original shape.  NOTE... the metal filings from the Parkling Pawl have, no doubt, found their way into the hydro oil and throughout the system.  Those tiny filings will scratch / scar the soft BRASS components of the Hydro pump and other internals...not just of the Hyd Pump, but also of the Hyd Motor that is bolted to the transaxle.   I would HIGHLY urge you to pull and inspect the HYDRO MOTOR, particularly the 9 soft brass PISTON SLIPPERS.  If you see that they look like these, you have a lot more to do than just refurbishing this parking pawl.  If the 9 brass faces of these piston slippers are smooth...without nicks or gouges, you are LUCKY.  Note...if these are damaged, the Hyd Pump like-kind components will also be damaged.   These parts can be saved....I've rebuilt a couple dozen of them.
BMW1
What is the original shape of the pawl?  Are the "notches" supposed to be there or should it be continuous metal with no notch?
We found most of the metal pieces in or near the strainer.  Why wouldn't the filter catch any other filings?
We got this tractor from someone else knowing there were transaxle problems.
I will look at the slippers.  If they are scratched, how does one fix them? are new ones available or do you use 400 grit sandpaper on a piece of glass?
Sarge
No, those notches in the pawl teeth do not belong that way - they need to be welded up and reground. Not an easy job and the welder must select the correct filler metal. I prefer to TIG weld them and use ER80SD2 on those - it is a lot tougher than 70 series filler and blends very well with the base material. Very fine particles can get through that screen and damage the slippers in both the pump and hydro motors - as well as the charge pump side of the main pump behind the engine. That pickup screen is generally not all that tight against it's sealing ring - some even fall off. These issues lead to a weak pump and motor - or total failure.  There are limits and specs about how much can be taken off those slippers facings by a total length limit - after that point, they need to be replaced as an assembly. There are suppliers out there that have the parts to fix the Sundstrand, totally worth the effort in my opinion due to its brute strength. Yes, you can face them off with a piece of glass and 320, then 400 grit and higher - the smoother the surface, the better. The matching faces in the pump and motor must also be faced - this has been outlined by Dave and others several times - do a search.
LJ Fluid Power in Michigan has a lot of the parts to fit this series pump in stock as well as gaskets.
Sarge
daveoman1966
Here are pics of the internal of the Sundstrand Hyd MOTOR.  Examine all of these and use a surface plate with 220  400  800 grit paper progressively ...by hand, in a wax-on-wax-off pattern to achieve a near-mirror finish removing as little material as possible. Also ensure the integrity of the bearing and O-ring seal.
NOTE... the components here are near identical to the Hyd PUMP and it will probably need attention as well.  I havfe pics of the pump internals...before and after...if wanted.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • BuffaloD200
      By BuffaloD200
      Hey all, I'm doing my first fluid change on my new-to-me D200.  Refilling the transmission is proving to be quite the struggle.  I've attempted to fill the tranny through the dipstick with a variety of funnels, but the oil just spills over the top.  I may have managed to get a quart in.
      What am I missing?
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
    • tomabrown77
      By tomabrown77
      my 1067 stopped moving; limited slip had worn out long ago;  now input pully is turning , but tractor doesnt move --- very slight motion forward or backward if on level ground with no resistance.  Enough to tell me shift lever is actually changing gears.
      I suspect input shaft woodruff keys but might be something worse ... i am interested in perhaps buying a new, used,or rebuilt  transaxle if someone has one they would part with.  And any advice on opening up the transaxle and looking inside .  Or where i can find parts to rebuild it myself...
      ps i was on forum about 5 years ago,  forgot my username so i joined again
    • Crazy Old Red Horse
      By Crazy Old Red Horse
      Barn find 1975 D180. 608 original hours. Tractor and 48” belly mower look to be still in their original paint. Rear 60” finish mower looks like it has had one coat of new paint added at some point. Open to trades. Please email me with any questions or for additional photos. 35 miles north of Pittsbugh.
