gwood
spray painting help, colors
gwood
35 minutes ago, WVHillbilly520H said:
One of my very first jobs out if high school was a Case/IH CUB CADET NewHolland farm equipment dealer, I spent 7 weeks wire brushing wire wheeling and D.A. sanding farm tractors, Cub Cadet garden tractors and various pieces of equipment then painting them with an older siphon feed spray gun, if were more than 1 tractor I believe I would invest in a HarborFreight HVLP gravity feed spray gun, there are "air" dry paints that aren't quite as nasty on your body but may be a bit "soft" after cured like spray bombs, or you can get the catalyst activated solvent dry paints that are more alone automotive grade, research research and research some more, but gun painting isn't any harder than rattle cans with a bit of practice, Jeff.
