Similar Content
By Mattgray
I am looking for a snow plow in the Western NC area, might be a long shot but iv checked marketplace and craigslist. No luck. if anyone has one or knows where I could get one. I believe I need a long frame one for my tractor. Thank you!! sorry if I posted this in the wrong spot. One year after owning my wheel horse and still running strong!
By TailGate18
Need help please
Can't exactly identify my wheelhorse. I believe I've pinned it between 74-79 but not sure exactly. I'm not real knowledged in mowers but interested in learning. It ran few years ago. Then parked in a storage unit for about 3 years with gas left in it. I can't get it to run at all unless using ether.
I've drained all the old gas, I've replaced the fuel lines, new plug, new gas, but it just won't start up and keep going. I figured on new carb but don't know exactly what I'm looking for and thought I'd better know the exact details of the mower so I know I get the right parts. Any help would be appreciated. The info I do have is as follows.
The mower itself all I could find was one tag on the frame under the gas tank.
ID # 61-08K801-05782
Then under that 4 digits
6337
Has a Kohler motor info as follows
Model-K181
Spec- 30538
Displ (cc)- 305
Serial #- 2613800539
It'll crank but not start. Not even attempt to start. With the fuel line off of the fuel pump it shows it pumps fuel. I thought the possibility of the float being stuck in the bowl but again not very knowledged in this field. Would appreciate any insight, details, knowledge, help or anything of the sort. Or info on the information of the tractor so I know exactly what I'm asking questions about
Says it's a B-80 8 speed
Thanks in advance
By nickjet67
Hi, been a while since I been on the forum, but I needed to log on to get some help with my "new" b-115 I picked up for $25! I saw this beauty sitting on the side of the road and I just needed to have it. only issue is it doesn't have a engine and the steering was all discombobulated. Last night I got that all welded up and now I am looking for help, I need to get the Briggs motor that came on it now, I have had 0 luck with finding the right motor for it but I have found almost every part I would need to build one from scratch. They are all over ebay and craigslist (the parts) and would be expensive but nice. Any help would be greatly appreciated! (also am looking for a snow blower and a bagger for it, dont know if the bagger for it exists but would be nice to have.
By dmhill
Does anyone know what drive belt and deck belt I need for the 1980 B 82? Also if anybody had pics of the drive belt installed I would appreciate it.....
When I picked it up both belts were/are missing. Not entirely sure all the necessary hardware is under there either, however, it seems complete. Thank you in advance.
By ken woolford
Advice please. Aquired a B-115 cheaply, bit of a basket case with four flats, but more importantly cannot select neutral. Gear lever moves freely throught range, and on jacking machine up appears all gears work, wheels turn, but cannot select neutral which makes it very difficult to push. Suggestions?
