Pullstart 63,097 #1 Posted January 13, 2019 I just realized that I will need to remove the rear hydro line on Frank to do final assembly some day. Due to the seat adapter I made, the 1-1/2” bolt won’t clear the fitting until it’s tight. Now, this line is well above the fluid level, but I assume the pump holds fluid too? How much Tran fluid should I expect to loose when I pull the hose? Drops, or a significant amount? Share this post Link to post Share on other sites
pfrederi 17,886 #2 Posted January 13, 2019 (edited) enough to make a bit of a mess 2-3 tablespoons... hold your finger over the hose end that will help Edited January 13, 2019 by pfrederi 1 1 Share this post Link to post Share on other sites
Pullstart 63,097 #3 Posted January 13, 2019 So it’ll drain the hose, more than the pump... not a huge worry. Thanks! 1 Share this post Link to post Share on other sites
pfrederi 17,886 #4 Posted January 13, 2019 Work Fast!! 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,096 #5 Posted January 13, 2019 How are you going to remove the hose? Is it a magic push-on connection? Garry Share this post Link to post Share on other sites
pfrederi 17,886 #6 Posted January 13, 2019 Open end wrench working down from the top in front of the tool box 1/12th of a turn at a time.... 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,096 #7 Posted January 13, 2019 4 minutes ago, pfrederi said: Open end wrench working down from the top in front of the tool box 1/12th of a turn at a time.... That should work for the first quarter of a turn and then what? Garry Share this post Link to post Share on other sites
Pullstart 63,097 #8 Posted January 13, 2019 13 minutes ago, gwest_ca said: How are you going to remove the hose? Is it a magic push-on connection? Garry 4 minutes ago, pfrederi said: Open end wrench working down from the top in front of the tool box 1/12th of a turn at a time.... I should be be able to get to it from inside my new tool box, with the seat removed fairly easy. 2 Share this post Link to post Share on other sites
953 nut 55,823 #9 Posted January 13, 2019 (edited) 47 minutes ago, pullstart said: So it’ll drain the hose, more than the pump... not a huge worry. Thanks! Knowing there will be a little leakage you can just fill the area with rags prior to breaking the fitting loose. Could you use a stud and nut in place of the 1 1/2" bolt to overcome the interference? Edited January 13, 2019 by 953 nut Share this post Link to post Share on other sites
Pullstart 63,097 #10 Posted January 13, 2019 2 minutes ago, 953 nut said: Knowing there will be a little leakage you can just fill the area with rags prior to breaking the fitting loose. Could you use a stud and nut in place of the 1 1/2" bolt to overcome the interference? I still need to get the spacer bolted in, and I’ve a feeling the thickness of it is causing my hiccup. A stud is a great Idea, but I’m not sure if it’ll help me. I do however plan to change the fluid before my build is finished up. I might drain the system first, then do the assembly, then fill it up. Share this post Link to post Share on other sites
953 nut 55,823 #11 Posted January 13, 2019 4 minutes ago, pullstart said: I might drain the system first, then do the assembly, then fill it up. You'll need a bunch of rags there too, thy burp a lot while filling. 1 Share this post Link to post Share on other sites
roadapples 6,983 #12 Posted January 13, 2019 (edited) When you disassemble to paint, I would notch that hole into a slot so you only need to loosen the bolt slightly instead of removing. And maybe use a larger washer.... Edited January 13, 2019 by roadapples Speeling 1 Share this post Link to post Share on other sites
Tractorhead 9,065 #13 Posted January 13, 2019 6 hours ago, 953 nut said: You'll need a bunch of rags there too, thy burp a lot while filling. If you work with right funnel and filled carefully i doubt that it burbs that much. Another issue may be a separate breater pipe (smaller than intake) or a sideway screw, where the filling can be checked. screw out fill slowly in if it drains on screwhole, bolt it up and youre fine. the easiest way as i found. Share this post Link to post Share on other sites
Pullstart 63,097 #14 Posted January 13, 2019 6 hours ago, roadapples said: When you disassemble to paint, I would notch that hole into a slot so you only need to loosen the bolt slightly instead of removing. And maybe use a larger washer.... That’s a great idea! After all, these holes used to hold down sheet metal and now a 3/4” thick block has been machined to take the sheet metal’s place. I could probably plug the hole and silicone a bolt head in place for all it matters, but a slotted hole might work out! 1 1 Share this post Link to post Share on other sites
