rdeanrj58 68 #1 Posted January 12, 2019 Anyone know what these 12" weights might be from ? Share this post Link to post Share on other sites
ebinmaine 69,346 #2 Posted January 12, 2019 Made to go inside the wheel. Any stamping numbers? Home cast? Share this post Link to post Share on other sites
CraigArndt 13 #3 Posted January 12, 2019 I think possibly Case tractors, that cut out goes around the axle, but I'm guessing. Share this post Link to post Share on other sites
WHNJ701 4,165 #4 Posted January 12, 2019 homemade would be my guess Share this post Link to post Share on other sites
rdeanrj58 68 #5 Posted January 12, 2019 I was thinking inside wheel weights. Not sure there's enough clearance though. Haven't found any numbers. Look a little too neat to be homemade I think 1 Share this post Link to post Share on other sites
ebinmaine 69,346 #6 Posted January 12, 2019 3 minutes ago, rdeanrj58 said: Look a little too neat to be homemade I think Don't let that fool you. Lots of us would make something neater in appearance if constructed ourselves for several reasons including having more time to put into it or being more caring because it's "yours". Have you measured the o.d. ? Share this post Link to post Share on other sites
WHNJ701 4,165 #7 Posted January 12, 2019 inside rear wheel weight doesn't make sense? I don't understand how it would mount to the wheel and the hub? Share this post Link to post Share on other sites
ebinmaine 69,346 #8 Posted January 12, 2019 5 minutes ago, jabelman said: inside rear wheel weight doesn't make sense? I don't understand how it would mount to the wheel and the hub? Might not be for a horse. Might even be for a larger tractor's front wheel. Or another make that has a different set up. Only guessing.... Share this post Link to post Share on other sites
rdeanrj58 68 #9 Posted January 12, 2019 Outside diameter is a full 12". Doesn't seem to fit the wheel very well because it doesn't go inside that first lip . Would need to be no more than 11 1/2". Width of slot is 2 1/4". Weights are 2" thick Share this post Link to post Share on other sites
ebinmaine 69,346 #10 Posted January 12, 2019 That being the measurements I'd say they're for a larger wheel for sure. I've seen weights for the front of farm tractors that were a 16" wheel that were around that size. Share this post Link to post Share on other sites
rdeanrj58 68 #11 Posted January 12, 2019 Yeah I'm beginning to think Cub Farmall ?? 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #12 Posted January 12, 2019 2 minutes ago, rdeanrj58 said: Yeah I'm beginning to think Cub Farmall ?? The Farmall Cub front wheels are 12", so the same wheel weights as the Cub Cadet which I have on the inside of my 520H... 1 Share this post Link to post Share on other sites
WHNJ701 4,165 #13 Posted January 12, 2019 maybe they are not wheel weights and came off some exercise equipment and someone drilled the 2 holes Share this post Link to post Share on other sites
rdeanrj58 68 #14 Posted January 12, 2019 Thanks for the pics Mr hillbilly. Those weights must measure . 11 1/2" since they fit down in that first lip. . Maybe I could trade these for some WH weights if I could figure out what they're for . I definitely think they're inside wheel weights for something 1 Share this post Link to post Share on other sites
aghead 72 #15 Posted January 12, 2019 looks like big scale weights to me...cotton scale? 1 Share this post Link to post Share on other sites
aghead 72 #16 Posted January 12, 2019 2 minutes ago, aghead said: looks like big scale weights to me...cotton scale? Share this post Link to post Share on other sites
rdeanrj58 68 #17 Posted January 12, 2019 Hmmm. Never seen anything like that Share this post Link to post Share on other sites
ebinmaine 69,346 #18 Posted January 12, 2019 29 minutes ago, aghead said: You might be onto something there. Share this post Link to post Share on other sites
Chris G 3,296 #19 Posted January 13, 2019 I would definitely agree on the large scale weight. That little groove and tab is made to interlock with the opening offset. So when the scale is being use the weights don't shift and fall off the weight hanger. 1 Share this post Link to post Share on other sites
Mows4three 826 #20 Posted January 13, 2019 Woah. Hold on there a minute fellas. You guys are just plain out missing the obvious here. To the trained eye, it's quite easy to see they are from the 1970s and came from a VERY heavy duty PAC MAN unit. You are welcome. Cheers! Dave 2 Share this post Link to post Share on other sites
ebinmaine 69,346 #21 Posted January 13, 2019 20 minutes ago, Mows4three said: Woah. Hold on there a minute fellas. You guys are just plain out missing the obvious here. To the trained eye, it's quite easy to see they are from the 1970s and came from a VERY heavy duty PAC MAN unit. You are welcome. Cheers! Dave You are close Dave. Very close. They are in fact a Pac Man archeological relic from the 5th century bc. The Chinese had just learned to melt iron (Western man wouldn't pull it off for nearly another 1600 years) and were enjoying some downtime by creating a new game. Traditionally played by fairly strong folk. One ran along a line of people holding sticks or reeds and tried to stuff or "pack" them in the "mouth" of the game piece. They were of course being chased by those trying to empty the game piece. A win was achieved as we all know by making it back to the goal. A more modern version of the game was produced in 1980 by neighboring Japan and was seen from the side in 2D so the sticks look like dots. Disclaimer: I may have fabricated parts of the story. 1 1 1 Share this post Link to post Share on other sites
Herder 2,354 #22 Posted January 13, 2019 (edited) ? WOW! How about using them as a door stop. Don't stub your toe. Edited January 13, 2019 by Herder 1 Share this post Link to post Share on other sites
rdeanrj58 68 #23 Posted January 13, 2019 Wow you guys are very knowledgeable. As rare as those are I think they're worth upwards of a grand. One of you smart guys should jump on that deal before I take them to the pawn stars in Vegas. Now... where did I put my scissors...... cause I'm ready to cut this thread ✂️ 2 Share this post Link to post Share on other sites
squonk 41,773 #24 Posted January 13, 2019 23 minutes ago, rdeanrj58 said: Wow you guys are very knowledgeable. As rare as those are I think they're worth upwards of a grand. One of you smart guys should jump on that deal before I take them to the pawn stars in Vegas. Now... where did I put my scissors...... cause I'm ready to cut this thread ✂️ " I need to call my weight expert in to check these out to make sure they are authentic. " 1 1 Share this post Link to post Share on other sites
