nickjet67
Rough B-115
nickjet67
Hi, been a while since I been on the forum, but I needed to log on to get some help with my "new" b-115 I picked up for $25! I saw this beauty sitting on the side of the road and I just needed to have it. only issue is it doesn't have a engine and the steering was all discombobulated. Last night I got that all welded up and now I am looking for help, I need to get the Briggs motor that came on it now, I have had 0 luck with finding the right motor for it but I have found almost every part I would need to build one from scratch. They are all over ebay and craigslist (the parts) and would be expensive but nice. Any help would be greatly appreciated! (also am looking for a snow blower and a bagger for it, dont know if the bagger for it exists but would be nice to have.
oliver2-44
Watch the classified here. There was a k321 14 hp listed that just sold.  Also @richmondred01 rebuilds motors and usually has a few on the shelf to sell.
richmondred01
I currently have a rebuilt k301 and a k321.
i have a k341 and m12 pending rebuild.
nickjet67
I might have to take ya up on that, I believe the Briggs that was on the mower was a 297905 or something like that
Thanks! I just did a little paint work tonight since I had some time lol
richmondred01
Ready to go complete rebuild.
Crank .010 under, bored .010 over, valve seats ground, new piston, rings, rod, rebuilt carb, all seal seals and gaskets.
The Tuul Crib
You might check with @Firebug.He helped me with a k321 for my 1067
richmondred01
Edited by richmondred01
nickjet67
36 minutes ago, richmondred01 said:
Thanks for the comment! But I need that vertical shaft Briggs 191707, it's a 1982 B-115 5-speed. But thank you for commenting
richmondred01
My pleasure. All the best.
nickjet67
@richmondred01 Is there any chance that you have any vertical shaft motors 8hp or more anywhere? Just curious. It would be nice to just hook up all the wiring stock but what ya gonna do lol. I have a Kohler motor that I have just sitting around (ill check the model when I get home), its off a 1977 b80, not sure the model of the motor but you can check if you want. I will send it to you if you want, last time I had it running was probably a year or longer ago. Maybe we can do a trade or something.
richmondred01
I’m sorry I don’t have any vertical shaft engines anymore. I just could never sell, or even give them away. I’ve scraped all of them at this point to make room.
  • Similar Content
    • bigbuck
      By bigbuck
      I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
      please call George at 517-499-5678 for more info.
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
