Stepney
Deck Baffles
Stepney
Hello, all. I seem to remember reading a post at one point, but I can't find it now. I have an old (rather rough) 42"RD from a vertical shaft machine. I have a decent 42"RD tach-a-matic deck as well. I'm planning to use this old deck as it's still in half decent shape. Should last quite a while when I patch it up. I don't have the model number on hand currently, but I did notice that it has baffles under it like my old 36" on my B100 had. (Had being a loose term, they are very rusted away). I remember mowing with a 42"RD years ago that had no baffles and it left a bit of an odd cut.
So in short terms, does it make much difference if they are there or not? Trying to figure if it's worth reconstructing them.
peter lena
I finished cutting out the badly rotted baffles' on a r/d deck I got , matched the finish work with a later deck model  I have 42 r/d . never had any irregular cutting or finish  with either deck , I do keep my blades sharp and regularly clean  the underside of any buildup. my own opinion is ,its not worth it , my finish work always look fresh with no issues , I like a r/d deck because it never leaves any build up.  pete
