Firebug
D series hydraulic cylinder
Firebug
Has anyone found a replacement cylinder for the d series. My cylinder for the belly lift has a slow bypass in it. Still lifts my plow but slowly drops, even without the weight of the plow. Looking at it I see the end caps are welded on so a rebuild isn’t possible. I know there are good used ones available but I was looking for a newer, rebuildable model
oliver2-44
@wheelhorseman offers a service to rebuild the welded hydraulic cylinders. Hopefully he will chime in and say if he can do the ones on the D series.
daveoman1966
Take the cylinder to a Tool & Die shop.  They can put it on a lathe and cut it open at the weld.  Replace the internal O-ring(s) and mig reweld it where it was cut open.
wheelhorseman
Yes I have did some D series short and fat hydraulic cylinders I have the seals on hand.
Firebug
Pm sent
