Firebug 267 #1 Posted December 31, 2018 Has anyone found a replacement cylinder for the d series. My cylinder for the belly lift has a slow bypass in it. Still lifts my plow but slowly drops, even without the weight of the plow. Looking at it I see the end caps are welded on so a rebuild isn’t possible. I know there are good used ones available but I was looking for a newer, rebuildable model Share this post Link to post Share on other sites
oliver2-44 10,367 #2 Posted December 31, 2018 @wheelhorseman offers a service to rebuild the welded hydraulic cylinders. Hopefully he will chime in and say if he can do the ones on the D series. 1 Share this post Link to post Share on other sites
daveoman1966 3,807 #3 Posted December 31, 2018 Take the cylinder to a Tool & Die shop. They can put it on a lathe and cut it open at the weld. Replace the internal O-ring(s) and mig reweld it where it was cut open. 2 Share this post Link to post Share on other sites
wheelhorseman 3,211 #4 Posted December 31, 2018 Yes I have did some D series short and fat hydraulic cylinders I have the seals on hand. 3 Share this post Link to post Share on other sites
