p38js
875 the first hydro
bds1984
On 4/26/2019 at 7:54 AM, p38js said:
And now to try and get this to fit on a short frame
It can be done!  I have always loved the sound of a big Briggs opposed twin!
Pullstart
16 minutes ago, 19richie66 said:
We use these on mowers. 190 cranking amps. You can get them a larger.
That looks like it’s a spec. model fir JD, do they make a red top?
  • Haha 2
Pullstart
That looks like it’s a spec. model for JD, do they make a red top?
p38js
This looks like a great option I will have to get measurements
p38js
Does anyone know what this adjustment is for?
ebinmaine
@daveoman1966
@pfrederi
gt14rider
That is a dampening valve, takes up pressure from acceleration valve to reverse valve,  manual stats clean with solvent, check for damage to the  pin or ball or if valve rattles when shaken, replace valve.
p38js
Gt14rider do you think that will solve my problem,  the transmission will take off in forward and almost pull the front end off the ground and barely move in reverse?.  I’m in the process of changing out all the o-ring in the reverse circuit and polishing the valve seats,  in the hopes that I have an internal leak
p38js
I think they sound awesome and they seem to have a lot of power and are smooth
ebinmaine
Is that a similar engine to what would have been in a Bolens st160?
That was a Briggs and Stratton twin.
Sounded great.
p38js
@ebinmaine i’m not sure about the Bolens but it is the same as a c161 twin
gt14rider
I think you are on the right track,  check springs and orings, forward and reverse valves, also check valves and springs item 9 and 10. Trouble shooting chart, Erratic engagement...... follow flow chart, check towing valve / hydrogear tune - up. Sundstrand manual,
gt14rider
Also check speed control lever for full travel and tention, make sure cam plate moves all the way, so you get full forward and full reverse range
p38js
That’s was my thought if none of that works I two extra rear ends to try
bds1984
They are grossly underrated and get a bad rep for many being put into cheaper mowers and poorly maintained.  My parents had one in a Yardman GT and it was a very smooth running engine that had power all day long.
p38js
I think I found my transmission problem new o rings and robbed springs from another transmission, can’t ops check yet waiting on a pump out put shaft seal 7877 sound be here this week. Does any one have a source for new springs?
gt14rider
Nla, if you find some let us know, looks like most common problem, try to flush as best you can, pieces of spring will wreck pump.
953 nut
Several years back @refracman had a source for the acceleration springs, send him a PM and see if he can help.
p38js
I flushed out the passages with some brake clean ran a magnet in all the bores and was getting some fine metal.  Drained the fluid and installed a new filter,  I hope I got all of it
gt14rider
Check plugs on bottom of the pump housing, Allen heads.
Sarge
Have you tried LJ Fluid Power for the springs?
Sarge
p38js
I swear this little tractor doesn’t want to go to the show, so I was trouble shooting the very slow in reverse motion and jerk your head off your shoulder and pull the front end off the ground.  I noticed that when in reverse there was a trail of fluid, so here is the problem
p38js
Lucky me I have 4 hydro units from several Gt14,  I took one apart and inside was completely trashed but the housing for the drive gear is in good shape,  I now have two cuted hydros now to make a Frankenstein hydro hoping for the best
  • Excellent 2
p38js
Ok guys here it is twin Briggs on a 875, has anyone tried this yet need a little help,  looking for options on an air filter, and trying to cut as little as possible out of the hood here is what I got so far,  I’m going to get a 1/4inch piece of flat steel to mount the engine on so I can move it around on the frame
  • Excellent 3
Pullstart
So cool!  Once you get the 1/4” plate under the engine, try cutting various blocks of wood at a certain thickness to sit on the carb and see if the hood clears.  In die making we used modeling clay to run a die over in the press to see where the stop blocks needed to be.  Maybe you could build a carb hat to relocate the filter like the GT-14?
