Pullstart 64,515 #151 Posted yesterday at 01:04 PM I made a list of things to accomplish on the belt guard. One major issue is the air filter. There is about 7/8” between the carb top and the hood. I have an idea. 1 1 Share this post Link to post Share on other sites
AlexR 1,290 #152 Posted 23 hours ago 1 hour ago, Pullstart said: I made a list of things to accomplish on the belt guard. One major issue is the air filter. There is about 7/8” between the carb top and the hood. I have an idea. My thought on a airbox would be make a fairly large square box that is only 3/4-7/8" thick. With a hole in the center for the air intake. And then attach a external air filter to that how ever that would have to work with space. But it will be interesting to see what you come up with. 1 Share this post Link to post Share on other sites
Pullstart 64,515 #153 Posted 20 hours ago 3 hours ago, AlexR said: My thought on a airbox would be make a fairly large square box that is only 3/4-7/8" thick. With a hole in the center for the air intake. And then attach a external air filter to that how ever that would have to work with space. But it will be interesting to see what you come up with. Surprisingly, a PTO clutch plate perfectly bolts to the top of the carb. I found an air filter that will fit down over the carb. So, a little cutting and welding magicery should allow it all to work in conjunction with each other. 2 Share this post Link to post Share on other sites
p38js 422 #154 Posted 19 hours ago Looks good Kevin, can’t wait to see it! I did hear the engine run before I bought it, the gentleman I got it from started it on the floor of his shop. But that has been several years ago. 1 1 Share this post Link to post Share on other sites
Pullstart 64,515 #155 Posted 18 hours ago 1 hour ago, p38js said: Looks good Kevin, can’t wait to see it! I did hear the engine run before I bought it, the gentleman I got it from started it on the floor of his shop. But that has been several years ago. Great news! It’s got enough compression to break my wrist! 1 2 Share this post Link to post Share on other sites
953 nut 57,871 #156 Posted 15 hours ago 2 hours ago, Pullstart said: break my wrist! had to figure this thread would wind up in the 4 Share this post Link to post Share on other sites
