Firebug 267 #1 Posted December 26, 2018 I have a d 200 that is my plow and tiller tractor. When I bought it there where turf tires on it and one was filled with calcium chloride. I little rust later that was removed. I put ag tires on it and had the left (drive) tire filled with washer fluid. Roughly 6.5 gallons, 47 pounds. Would there be any benefit to filling the right one? I’m thinking of filling both fronts just for the weight when the tiller is on. Plus a weight bar. On a similar note. I picked up a c 160 8 speed with a brinley plow. It is going to be dedicated just for that for plow days and gardening duties. I’ve read that guys are loading them up with weight. Is there an advantage to filling both rear tires and the fronts for that application. I’m leaning toward sticking with the washer fluid because it’s fairly inexpensive, about $20 to fill a 15 inch d series rim, and it’s non corrosive. Mare there any other tricks guys have done to add weight? Any thoughts on filling one or both rear tires? Any problems with filling the fronts? Thanks guys 1 Share this post Link to post Share on other sites
953 nut 57,861 #2 Posted December 26, 2018 The more weight you can put in or on the wheels and tires the more stable it will be. I don't know if filling only one rear tire will harm anything, but I would fill both rears. SIZE GALLONS Per Tire WEIGHT in POUNDS 16x6.50-8 2.0 21.4 18x7.00-8 3.0 32.1 18x8.50-8 3.4 36.4 18x9.50-8 4.0 42.8 23x8.50-12 5.5 58.9 23x10.50-12 6.8 72.8 6-12 3.6 38.5 1 Share this post Link to post Share on other sites
Firebug 267 #3 Posted December 26, 2018 So for any application it would be recommended to fill both rears Share this post Link to post Share on other sites
cschannuth 3,817 #4 Posted December 26, 2018 52 minutes ago, Firebug said: So for any application it would be recommended to fill both rears I would say yes. I run rear fluid in all my tractors. It really plants them firmly to the ground. Share this post Link to post Share on other sites
ebinmaine 70,699 #5 Posted December 26, 2018 6 hours ago, Firebug said: So for any application it would be recommended to fill both rears Absolutely. Most of these tractors are not limited slip. Filling only one tire would benefit that tire but leave the other one with less traction in high torque situations... Thus will spin sooner. Share this post Link to post Share on other sites
KC9KAS 4,743 #6 Posted December 26, 2018 I would fill both rear tires. Windshield washer fluid is 8.34-8.5 pounds per gallon. Liquid Ballast Comparison Table Type Cost Freeze Resist Weight vs. Water Safe? Availability Water free none +0% very safe wide Calcium Chloride low/high* -50F +40% corrosive wide Ethylene Glycol Antifreeze medium -40F +0% toxic wide Propylene Glycol Antifreeze high -40F +0% safe wide Windshield Washer Fluid low -20F +0% toxic wide Methanol medium -15F +0% very flammable wide Beet Juice very high -35F +30% very safe dealer network Polyurethane Foam/Flat Fill very high +20-50% very safe dealer network *using CaCl2 is low cost if containment tubes are already available and installed, otherwise this is a high cost option Water Water has been used as ballast inside the rear tires of tractors operated in warmer climates for years. In geographical locations where freezing occurs, an additive is necessary to prevent the water from becoming an ice block inside the tire. Ballast that does freeze inside the tractor will make those tires unstable and general operation of the tractor unsafe. Water is the least expensive form of liquid ballasting and weighs 8.3lbs per gallon. Advantages readily available no cost safe to use – non-toxic, non-flammable easy to install into tires Disadvantages not suitable for cold climates Calcium Chloride Calcium chloride, CaCl2, in powdered form can be mixed with water to produce a liquid that will resist freezing up to -50F, depending on the strength of the concentration. Calcium chloride weighs about 11.5lbs/gallon mixed, so more ballast weight is achieved in the same volume, allowing a heavier ballast. This type of liquid ballast is a highly corrosive mixture so care must be taken in handling this product. CaCl2 should be installed into tubes regardless of whether or not the tire on the tractor is tubeless. Without being contained in a tube the mixture will rust the rim flange area right out. Advantages easily obtained in large quantities high weight/volume ratio (almost 40% more than water alone) very high freeze resistance Disadvantages care taken when used – corrosive mixture must be installed into tubes – extra cost if installed without tubes corrosion/rust of the rim will occur puncturing a tire filled with CaCl2 will spray rust-causing mixture everywhere, damaging sheet metal and vegetation A typical 50lb bag of calcium chloride with inset image showing powder consistency. Ethylene Glycol Antifreeze Antifreeze, mixed 50/50 with water, and installed into your Kubota’s rear tires, will provide the same amount of weight per gallon as water and will resist freezing to approx -40F. Ethylene glycol antifreeze is classified by Canada’s Environmental Protection Agency as hazardous waste after it reaches the end of its useful life. Care must be taken when disposing of this type of ballast – and in the case of a tractor tire, there will be a lot of mix to deal with. Advantages easily obtained in large quantities high freeze resistance safe to mix – non-flammable but is toxic if ingested Disadvantages hazardous to the environment, animals and people – care must be taken regarding its disposal could get costly if your only source is 1 gallon jugs at a Walmart Propylene Glycol Antifreeze Propylene glycol is known as a non-toxic or people/animal friendly antifreeze. Besides its antifreeze properties, it is actually used in many cosmetics, pharmaceuticals, shampoos and as a food additive. Dow, who manufacturers 35% of the world’s supply of of propylene glycol, reports that in the United States, 22% of production is used for antifreeze or de-icing. When installed into your tires as a ballast in a 50/50 mix, expect similar properties to ethylene glycol, high freeze resistance with ballast weight similar to that of water alone. AMSOIL makes this type antifreeze available by the gallon or 55 gallon drum. Advantages easily obtained in large quantities high freeze resistance safe to humans, animals and vegetation, non-flammable, non-toxic and biodegradable Disadvantages more costly than plain old toxic ethylene glycol – sources we used, quoted prices of 33%-120% more per gallon Windshield Washer Fluid Washer fluid, installed right from the jug is freeze protected to about -20F and provides about the same ballast weight properties as water does. Washer fluid has some of the same chemicals in it that antifreeze does, but at milder concentrations. Disposing of gallons and gallons of washer fluid, as in the case of tire ballast, would require care. Advantages easily obtained in large quantities low cost adequate freeze resistance no mixing required – use as is, non-flammable but is toxic Disadvantages hazardous to the environment, animals and people – care must be taken regarding its disposal Methanol Methanol is highly flammable and if you decide to use this product it must be mixed with water to make it so you do not blow yourself up while mixing it, installing it, or driving your tractor with it in there. Depending on strength of mixture, methanol and water is good to around -15F temperatures. We are not recommending the use of methanol and water because of the danger – but it is an option available for tire ballasting. Advantages easily obtained in large quantities adequate freeze resistance Disadvantages extremely flammable mixing required with water hazardous to the environment, animals and people – care must be taken regarding its disposal Beet Juice Beet juice, a liquid byproduct made from de-sugared sugar beets. This food grade product is available in the US under the trade and brand name, RimGuard. This liquid weighs about 30% more than straight water and resists freezing to about -35F. Best of all, it will not solidify until the temp drops to -50F. Natural, non-corrosive, safe to the environment and humans. If beet juice is available in your location, we believe this your best bet – safe to use and provides extra ballast weight. Advantages high weight/volume ratio (about 30% more than water alone) very high freeze resistance anti-rust properties a natural product – environmentally friendly and safe Disadvantages may not be available in all locations Polyurethane Foam/Flat Fill This ballast method is essentially a run-flat polyurethane fill that is injected into the tire through the valve stem. Two liquid components are pumped into the tire and they react with one another so that 24-36 hours later, you are left with a solid rubber core – the air inside the tire is completely displaced. The term “foam” is a bit misleading – the core is actually very much a black solid. It is sometimes called foam because air bubbles are injected into the mix to control the density of the end product. This ballast method obviously adds serious weight gains to each tire and also has the nice benefit of eliminating flat tires and associated repair costs. Because the tire is run-flat there is no risk of corrosive/toxic ballast spraying all over your tractor and scorching vegetation if you do spring a leak. You will have to find a dealer near you that performs this service (Brannon Tire in Stockton, California for example). Advantages high weight/volume ratio (about 20-50% more than water depending on type of fill) cannot freeze tire is run-flat simple – have it done once, ballasted forever Disadvantages may not be available in all locations high cost – prices range around $0.95-1.25 lbs injected, or $300+ per tire tire must be cut off rim after tread wears out – best for new or nearly new tires if performed on steering tires, heavy duty weight gains will put more stress on steering components no air in tires to absorb humps and bumps so you will get a very rough ride – could be jarring for long distance travel 2 1 Share this post Link to post Share on other sites
Firebug 267 #7 Posted December 26, 2018 Great chart filled with a lot of info. I appreciate the help. Looking at staying with the washer fluid. It’s readily available at the tire shop I frequent and cheap. If I fill the front tires how will that effect the steering? 1 Share this post Link to post Share on other sites
rdeanrj58 68 #8 Posted December 26, 2018 This is very interesting. I'm sure it's been discussed here before but can we talk about how this is done ? Is it better to use tubes ? How much liquid is put in tire ? And how much air pressure is put in afterwards? Thanks Share this post Link to post Share on other sites
Firebug 267 #9 Posted December 26, 2018 My turf tires were tuned and had the calcium chloride in them. My ags are not tubed and have washer fluid. I didn’t get to see the whole process but from what I did see the guy broke the tire bead and just started dumping fluid in.at the top. Got about 6 gallons in then he aired it up to reseat the bead and left it at 15 psi Share this post Link to post Share on other sites
Razorback 1,069 #10 Posted December 26, 2018 (edited) 11 hours ago, rdeanrj58 said: This is very interesting. I'm sure it's been discussed here before but can we talk about how this is done ? Is it better to use tubes ? How much liquid is put in tire ? And how much air pressure is put in afterwards? Thanks There is an adapter that is made for filling the tires. Do a web search for Slime 20073. Slime ballast adapter I recycled some antifreeze in the tires I loaded. Works good. There are videos on YouTube that show the process. Here is one: Filling a tire with fluid Edited December 27, 2018 by Razorback Share this post Link to post Share on other sites
WHX?? 50,700 #11 Posted December 26, 2018 Yes KC9 ... I've seen that posted before need to save it for future. 1 Share this post Link to post Share on other sites
rdeanrj58 68 #12 Posted December 26, 2018 Ok thanks guys. I'll have to give it a try Share this post Link to post Share on other sites
KC9KAS 4,743 #13 Posted December 26, 2018 (edited) That didn't turn out like I wanted it to! I bought one of these adapters I think at NAPA or some other auto parts store. Installing Liquid Ballast in Tires Liquid Ballast Installation Filling your tractor tires with water can be easy with GEMPLER'S liquid ballast adaptors. Use the guide below to learn how to use each type of tool and click here to view GEMPLER'S supply of liquid ballast products. Air/Liquid Adapter Quick Fill Attachment Core Injection Tool Differences Using the Air Liquid Adapter Kit The Air/Liquid Adapter Kit permits fast filling of tires with fluid for ballast. Button valve on side releases air displaced by fluid. Connects 3/4" standard garden hose to air/liquid tractor stem "TR 218A/220A" and comes with 2 extra bushings to accomodate "TR 13" and "TR 15" stems. Parts included in the kit. Edited December 26, 2018 by KC9KAS Share this post Link to post Share on other sites
Herder 2,354 #14 Posted December 26, 2018 Tractor Supply sells RV antifreeze its an alcohol base, non toxic and is good to -50 degrees and runs about $3.00 per gallon. I cut it by 50% with water. Thats all i use. I would suggest using tubes. Tractors Supply caries them too. If possible try to get the Martin brand tubes the Traveller brand tubes are heavy duty and hard to work with when using an air to water valve. Ya sorry i should have mentioned a transfer pump is necessary. Be crafty you can rig-up some type of pump to to load your tires with. Share this post Link to post Share on other sites
ebinmaine 70,699 #15 Posted December 26, 2018 I think is was @pullstart ?? Uses an air tank... 1 Share this post Link to post Share on other sites
briankd 819 #16 Posted December 26, 2018 i filled both front and rears on my 857 windshield washer fluid best thing i ever did. bought this filler thing at walmart to fillem with think it was like 10 bucks . got tires filled and makes a difference in traction Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #17 Posted December 27, 2018 (edited) I have used a 2-3gal weed/garden sprayer with the end nozzle removed and then using a clear piece of 5/16"-3/8" tubing clamped to the coreless valve stem and nozzle pumped 5 gal into (each of the the first set of AGs I put on the Anniversary 520H) of course you will have to periodically stop and loosen the clamp to bleed the air out from pumping the RV ANTIFREEZE (what I used) or washer fluid into the tubed or tubeless tire...BTW after the fluid of choice is in you tires the rubber is actually an insulator so the freeze point actually increases past what the jug states,... but the last 2 sets I just had the tire shop add fluid (Methanol) when they installed the new ones. Edited December 27, 2018 by WVHillbilly520H 1 Share this post Link to post Share on other sites
WHX?? 50,700 #18 Posted December 27, 2018 Now ain't that true Hillbilly fashion...grab the old weed sprayer when your done killing yer neighbors lawn and load yer tires! Just Jeffery You mentioned a tire shop added methanol ..isn't that kinda bizarre for a pro tire or ag shop? I woulda thunk they would have used Rimguard as most pro shops do today? Gonna call a few local shops just for $h!ts & grins to see what they use and $$. Usually they charge by the lb that much I do know. The brunt of this discussion firebug is that ALL tractor men will agree upon is loading your tires is the best thing you can do for any size machine. I agree for one reason. It puts the weight on the ground, same with wheel weights, and not on the tractor's under designed transmissions or powertrains. Not that we have to worry about it with our horses. It does rob some power to turn that weight but again most would agree the sacrifice is worth the cause. 1 Share this post Link to post Share on other sites
ebinmaine 70,699 #19 Posted December 27, 2018 17 minutes ago, WHX21 said: Rimguard Rimguard Corporation themselves would be very happy to answer the phone and tell you which dealers are in your area. They were very helpful to me in locating somebody. 19 minutes ago, WHX21 said: does rob some power to turn that weight but again most would agree the sacrifice is worth the cause. I'm not by any means a physicist and I couldn't elaborate on the difference between liquid being in a tire and the solid weight being on the tractor or bolted to the wheels... There are those who say that liquid filling the tires adds a nearly negligible strain because you're constantly moving the fluid through the tire instead of carrying it or pushing it out of the way. I can tell you quite well for sure that loaded front tires are much much harder to steer. I most certainly agree that all rear tires at the very least should be filled. All four of mine are filled and I wouldn't have it any other way. 1 1 Share this post Link to post Share on other sites
WHX?? 50,700 #20 Posted December 27, 2018 24 minutes ago, ebinmaine said: 46 minutes ago, WHX21 said: I'm not by any means a physicist and Neither am I EB but logic dictates it's gonna take some extra HP to turn them tires when yer buried up to the axles? Share this post Link to post Share on other sites
Pullstart 64,495 #21 Posted December 27, 2018 13 hours ago, rdeanrj58 said: This is very interesting. I'm sure it's been discussed here before but can we talk about how this is done ? Is it better to use tubes ? How much liquid is put in tire ? And how much air pressure is put in afterwards? Thanks 2 hours ago, ebinmaine said: I think is was @pullstart ?? Uses an air tank... Yep, I’ve got a 5 or 6 gallon portable air tank, I pull the air chuck/gauge nipple from the tank, fill it up with used antifreeze with some help of a funnel, put it back together and charge it with 30 or 40 psi of air, flip it over and fill the tubes with the air chuck. Keeping the schrader valve at the top of the wheel and slightly tipped back helps, and I periodically bleed out residual pressure in the tube. I run virtually no air pressure in the tires once full of liquid and have so much more traction without negative effects on the lawn. 2 Share this post Link to post Share on other sites
ebinmaine 70,699 #22 Posted December 27, 2018 16 minutes ago, WHX21 said: Neither am I EB but logic dictates it's gonna take some extra HP to turn them tires when yer buried up to the axles? Yes! Quite true. Share this post Link to post Share on other sites
WHX?? 50,700 #23 Posted December 27, 2018 And ther you have it .... another Billy putting used crap in his tires! Actually I have seen guys putting used antifreeze in tires but not for me ... I like virgin stuff! Never know what stuff has been mixed with what. Course if your a billy! 1 Share this post Link to post Share on other sites
Pullstart 64,495 #24 Posted December 27, 2018 (edited) 2 minutes ago, WHX21 said: And ther you have it .... another Billy putting used crap in his tires! Actually I have seen guys putting used antifreeze in tires but not for me ... I like virgin stuff! Never know what stuff has been mixed with what. Course if your a billy! It was free on CL, how could I go wrong? Edited December 27, 2018 by pullstart Fat fingered it, or auto correct.. 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #25 Posted December 27, 2018 4 minutes ago, WHX21 said: And ther you have it .... another Billy putting used crap in his tires! Actually I have seen guys putting used antifreeze in tires but not for me ... I like virgin stuff! Never know what stuff has been mixed with what. Course if your a billy! I prefer the RV antifreeze if I'm doing it myself, and as far as the professional tire shops yes methanol even the dealer I bought the eMax from loaded the rears with methanol, seat the bead then break down just a small area insert hose and pumped my tires full then aired back up to re-seat that bead on the 23x10.50s, I suppose they used that schrader valve tool on the eMax as I wasn't there when fluid was added. Share this post Link to post Share on other sites
