Goldnboy
Spindle key
Goldnboy
I was reading through SB #429 and it shows the 3/4" spindles woodruff key removed and a jam nut and lock washer used. Have any of you done this? I see the lockwasher is NLA so is it a ordinary lockwasher? Is the jam nut a locknut style? That would would be odd because I never seen a lockwasher used with a locknut before.
gwest_ca
Just a standard spring lock washer and regular nut. The direction of rotation keeps it tight. The only requirement is that the pulley spins freely on the shaft before the lock washer and nut are added so it can tighten if necessary. A good time to apply Never-seize to the shaft to ease removal later.
This is how all the spindles were from the factory since the last design change.
Garry
953 nut
Jam nuts tend to be a bit thinner than regular nuts. You can get six of them for less than $ 6.00 including shipping on :techie-ebay:
6 Pack 3/4-16 RH STEEL JAM NUT NUTS
6-Pack-3-4-16-RH-STEEL-JAM-NUT-NUTS
gwest_ca
I doubt a thin jamb nut or the spindle threads would withstand the 50-90 Ft. Lbs. of torque specified.
Garry
953 nut
Garry
These are the nuts that I use to retain the blades on my :wh: mowers and I use a pneumatic impact gun to install and remove them.
Jam nut
From Wikipedia, the free encyclopedia
Jump to navigationJump to search
Standard nut employed as a jam nut against another standard nut
A jam nut is a low profile type of nut, typically half as tall as a standard nut. It is commonly used as a type of locknut, where it is "jammed" up against a standard nut to lock the two in place. It is also used in situations where a standard nut would not fit.
The term "jam nut" can also refer to any nut that is used in the same function (even a standard nut used for the jamming purpose). Jam nuts, other types of locknuts, lock washers, and thread-locking fluid are ways to prevent vibration from loosening a bolted joint.
Use[edit]
A jam nut is often used when a nut needs to be locked in place without clamping against another object. The jam nut essentially acts as the "other object", as the two nuts are tightened against each other. They can also be used to secure an item on a fastener without applying force to that object. This is achieved by first tightening one of the nuts onto the item. Then the other nut is screwed down on top of the first nut. The inner nut is then slackened back and tightened against the outer nut.
Jam nuts can also be used in situations where a threaded rod must be rotated. Since threaded rods have no bolt heads, it is difficult or impossible to apply torque to a threaded rod. A pair of jam nuts is used to create a point where a wrench may be used.
Jam nuts can be unreliable under significant loads. If the inner nut is torqued more than the outer nut, the outer nut may yield. If the outer nut is torqued more than the inner nut, the inner nut may loosen up.[1][2]
References[edit]
  1. ^ Barrett, Rich. "Fastener Design Manual". Retrieved March 20, 2009.
  2. ^ "The Use of Two Nuts to Prevent Self Loosening". Retrieved May 18, 2014.
Achto
That's because you've never worked with the genius's that I have to deal with every day.:lol:
  • Haha 1
Goldnboy
Jam nut
Use[edit]
References[edit]
I did that when i was a kid all the time when i had no money working on the farm and was scavenging for anything!
Achto
