JoeM
WH Plow Brush Add On
JoeM
A friend of mine gave me this brush that he had mounted on the front of his 48 inch WH Plow. Says he used it because his driveway is gravel and it solved the problem of digging it up when plowing snow. He since paved the drive and passed it on to me. I installed my plow today and brush today, just need some snow to try it out. I'll post the results later.
WHPlowBrush3.jpg.937a36b467c4a5173727f5a9e0fd28ea.jpgWHPlowBrush2.jpg.a257077ae54eb5ca69b241f86abe6b9d.jpgWHPlowBrush1.jpg.7d10ac5a275b34a89b405fbb4eae99ab.jpg
  • Like 5
ebinmaine
Interesting idea.
I'm curious to see how you like it.
wallfish
:text-yeahthat:
Chris G
2 hours ago, ebinmaine said:
Interesting idea.
What he said
AMC RULES
:text-yeahthat:  :text-+1:
 :wwp:
squonk
You'll have an excuse to bring the tractor into the house too! :)
  • Haha 3
MalMac
If that works, it’s a million dollar idea.
The Tuul Crib
Same here!
JoeM
I finally got to use the plow with the brush, worked good. Although we only had 3-4 inches of snow it did push the snow and not much of the gravel driveway.
I didn't have my film crew so I took a pic, I may try to get a video or more pics next storm.
  • Excellent 2
  • Similar Content
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
    • Nuzmuz
      By Nuzmuz
      Just wanted to show a modification I did to my 1990 310-8. I recently picked up a 36” tiller for my horse and I tried it out on my new garden area. After hitting a rock, it knocked one of the axle brackets open dropping the right side of the tiller. On a manual I viewed, it had clevis pins to hold the lever in, but my bracket did not have them. I drilled a 1/4” hole through on each lever and mounted a 1/4” clevis pin and hairpin cotter to reinforce the lever. I read on another post to just tighten the bolts on the levers, but I think this will work a little better. Hope this helps someone!
    • ToroMan
      By ToroMan
      Good afternoon, looking for some help regarding a plow assembly for a 1999 520xi model # 73542.  I'm told that a traditional Wheel Horse plow assembly will not fit this tractor, that the xi series requires a special plow assembly.  Problem is, most of the people selling plow assemblies don't seem to know what they have, and I don't know what I need!  I have included the supposed model numbers pulled from the Toro website, including that of a retrofit kit, but I'm not sure what that retrofit kit does! Does it enable me to fit a traditional Wheel Horse plow to an xi model? Don't know.  One guy selling a plow knew what type of plow he had and told me it would not fit my tractor, stating "Lift link and handle are in the wrong locations."
      Any help would be greatly appreciated. Just need to know what the hell I'm looking for, which might help me find it!
      From Toro site:
      Model #: 79355
      48" Snow/Dozer Blade
      Model #: 95-4090
      48" Dozer Blade Retrofit Kit
      Thanks!!!
    • Marc M.
      By Marc M.
      Hi guys I'm new to the wheelhorse world and i recently picked up a for 416-H and I'm looking to buy/install a plow put on it. I have found one on craigslist but I can't tell if it will work on my tractor or not, it is a wheelhorse plow though. Can somebody please send a photo or even a video of how to hook up a plow to a 416 or equivalent tractor?
      Attached is my tractor and the plow I'm looking at. Will it fix and what's it missing ?!
