Vinylguy 4,691 #1 Posted December 6, 2018 Is there a chance anyone can post pictures of the decals that were originally on a 5-0721. 36 inch side discharge deck. 1973 and 1974 was the year for them. Thaks Vinylguy Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,209 #2 Posted December 7, 2018 Terry Do you keep track of the original part numbers? Found 4 in the parts list for the 5-0721 4570 - Caution decal replaced by 93-1122 Danger decal on yellow triangular background so may be different. https://www.partstree.com/parts/toro/parts/93-1122/ 102601 - Height adjustment replaced by 106748 which may be different. https://www.partstree.com/parts/toro/parts/106748/ 102962 - Mower width side discharge 103666 - Belt installation listed for these decks https://www.partstree.com/parts/toro/parts/103666/ Garry Share this post Link to post Share on other sites
Vinylguy 4,691 #3 Posted December 7, 2018 (edited) 5 hours ago, gwest_ca said: Terry Do you keep track of the original part numbers? Found 4 in the parts list for the 5-0721 4570 - Caution decal replaced by 93-1122 Danger decal on yellow triangular background so may be different. https://www.partstree.com/parts/toro/parts/93-1122/ 102601 - Height adjustment replaced by 106748 which may be different. https://www.partstree.com/parts/toro/parts/106748/ 102962 - Mower width side discharge 103666 - Belt installation listed for these decks https://www.partstree.com/parts/toro/parts/103666/ Garry Thanks Garry My customer found a picture on ebay that he said was identical to his deck. Th belt route is hard to get a close up view and appears to be just a bit different than the one I have ? . Edited December 7, 2018 by Vinylguy Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,209 #4 Posted December 7, 2018 This appears in the operator manuals for other 1973-74 mower decks and will guess it is a 4570 as listed in the parts lists for those decks. Slightly different than what you have but maybe this is in the manuals only. Not having any luck with the belt decal. Garry Share this post Link to post Share on other sites
