Chris1055
Snowblower reducing bushing for bearing
Chris1055
Hi guys. I’m replacing the cross shaft bearings in my snowblower. Didn’t want to pay the toro price of 60 a bearing so I looked the thread up on the replacement and I actually found a pair sb205 bearing that will work. But the number for the reducing bushing i can’t look up the number. Is it a Bronze with a flat back ?? I would greatly appreciate for some info on it and where I could find one.
Thanks
Achto
Is this the style that you are looking for?
If so, figure out your inside dimension, outside dimension and length. Then try your local hardware store or Tractor Supply.
Chris1055
That’s what I’m trying to figure out. My question is are they using the style with the flat backing them? The dimensions I know. 7/8 putter 3/4 inner
roadapples
The ones I used did not have that outer edge... don't think I had room...
jay bee
@rmaynard did a nice post on this subject and @WHX21 did a great follow up that has helped me rebuild a couple of my snow blowers.  Hopefully it will help you also.
Edited by jay bee
