Similar Content
By Nuzmuz
Just wanted to show a modification I did to my 1990 310-8. I recently picked up a 36” tiller for my horse and I tried it out on my new garden area. After hitting a rock, it knocked one of the axle brackets open dropping the right side of the tiller. On a manual I viewed, it had clevis pins to hold the lever in, but my bracket did not have them. I drilled a 1/4” hole through on each lever and mounted a 1/4” clevis pin and hairpin cotter to reinforce the lever. I read on another post to just tighten the bolts on the levers, but I think this will work a little better. Hope this helps someone!
By RedWheelz
Will a 36" side discharge deck off a C-121 fit the 300 series tractors?
By JAinVA
Greetings from VA
The 300 series are very popular for many reasons.Out of curiosity when did WH switch from the 1" axle to the 1 1/8" axle on the 300 series? Rexemouse has said that his dumpster find 300 had 1 1/8" axles..I like the idea of the beefier transaxle but the 300 series seems tobe easier to come by than the 400 series I would like to know which years have the heavier axles.Thanks in advance.JAinVA
By halseyn
Just thought I'd post my new (used) 2000 314-8 I found at a local dealer, only has 215 hours, with a 42" RD deck in excellent shape. This makes the 5th one for my herd. Looking forward to mowing next year with this instead of my SK 482.
By boovuc
Can someone do a quick measurement for me? I need measurements of the front hub dust covers/grease cups used on most of the Wheelhorse Tractors. (300, 400 500 & C-Series)
I don't have one on my bench anymore and the one I wanted to measure on my C-175 won't budge and I don't want to ruin it just to measure. I have none on four of my machines and I'm tired of the crap they pick up.
I need the Inside Diameter
The Outside Diameter
The Depth or length
Didn't see anything on the dimensions while searching the site.
Thanks in Advance!
