Snowthrower Bearings
By
RichInWalworth, in Implements and Attachments
Similar Content
By Jeff_B
Where's your go-to source for QUALITY 103119 bearing shaft assemblies? Also, I don't have my deck apart yet, but seem to remember they're tough to remove from the housings. Any tips or tricks? Finally, just recently I've had a couple of the center bearings go loose on two different decks. Once is one thing, but twice? More than a coincidence? Should I be releasing tension on the belt by loosening the mule drive when not in use? We've had WH tractors for over 40+ years and I've never done that before! THANKS in advance!
By IthacaJeff
Hi folks:
The wheel bearings in one of the front wheels of my 416-8 imploded the other day while mowing. 32 years old, I'm not complaining. Anyway, with the advice of another thread I picked up a set of 4 flanged bearings off an ebay seller. . .3/4" ID, 1 3/8" OD. Problem is they are a loose fit in the wheel hub. I should need to tap them in, but they just slide in and out. No real play, but they can just fall out. The insides of the hubs are clearly worn. Any advice on snugging up the bearings"
Thanks,
J
By porschpow
Good Morning everybody!
I am in the process of sharpening the blades for my mowing deck (Model 78360 - Serial 7904987) and I noticed that the deck has a crack in it right where the bracket to the mounting hardware (to the tractor) is. SO I know I have to get that repaired.
But while I was at this, I thought I could do a good quick once over on the deck to make sure I am ready for the season.
What I would like to do is the following:
Change the bearings for the spindles (or pack them with more grease)
Get new rear tires (since they squeak)
And that's about it
If anyone here thinks I should do anything else, I would love to hear it!
Where does everyone get the hardware (bearings, wheels for these rebuilds?)
By mkueb
Does anybody have a good source for replacement front wheel bearings for a mid to late 1970's D160 wheel horse tractor? There are two push in bearing units (inner and outer) per wheel. I first attempted to replace with standard bearings but quickly found out these are not standard sizes. It's been a while since I check and I don't completely remember, but I think the wheelhorse bearings where something like 1/16" of an inch larger OD than a standard catalog bearing. At the time, I remember finding bearings but they wanted somthing like $100 for each bearing. I was able to located two bearings and did purchase them for a reasonible price, but am still looking for two for completing the set. The part numbe ron the two that I was able to locate is 104396. If anybody has any ideas, I would appreciate.
Thanks
Marc
By Horse playing
Hello, everyone and thank you in advance. I got bit by the bug a few months ago and bought a 1974 b 80 the rod broke, about a month after i bought it. So to keep my 4yr old mowing i picked up a c120 auto and i was going to change rear wheel seals pulled the hub to find the axle moves up and down and side to side about an 1/8" what's involved in put in new bearing and does it need to be done now or a winter project. Thanks
PS sorry about the grammar
