Navig8r
Short Chute pulley size/availability
Navig8r
I'm having trouble putting the pieces together on which pulley will fit... Know I have a 3/4" shaft with 5 1/2" original pulley.. OEM is crazy money, but not sure if some of the replacements I'm finding will take the 5/8" wide belt..... Anyone know what section width this belt would be (5L perhaps?)
Was looking at this from TSC.... https://www.tractorsupply.com/tsc/product/phoenix-standard-a-b-type-3-4-steel-drive-pulley-5-in-od?cm_vc=-10005
I know its a 5" vs. 5 1/2"... wouldnt mind running just shy of full throttle if all else is good.
Any help is greatly appreciated as is all the help I've already gotten trying to get this thing together!
gwest_ca
It says A/B type.
Assuming that is the belt width A being 1/2" and B being 5/8".
Most replacement pulleys will accept both belt widths. The narrower belt will give a slightly smaller effective diameter.
Garry
  • Thanks 1
wallfish
:text-yeahthat:
You can also find cast pulleys of many sizes here.
https://www.surpluscenter.com/Pulleys/Finished-Bore-Pulleys/?page_no=1&fq=ATR_Grooves:1&fq=ATR_Bore_Fractional:3/4\"
Not sure the pic for 5.45" D is correct as a spoke pulley. I've ordered many different pulleys and they weren't spoke pulleys until the larger diameter around 8 inches. Not like it makes any difference anyway but...
  • Thanks 1
peter lena
you might also check your local  BEARING DISTRIBUTOR , they specialize in belts, pulleys ,and bearing related problems. pete
AMC RULES
...or, if you know the factory :wh: part number...
our very own :rs:classifieds.   :greetings-wavingyellow:
  • Thanks 1
Navig8r
I saw this, but saw a post at the end that said these pulleys were no longer available, I guess I should message him.....
AMC RULES
Can't hurt to touch bases.
Just discovered yesterday, another source for NOS original dealership parts here local to me too.
Navig8r
Care to share that source?  :)
.... I'm not far from you... I'm in Gardiner, and travel Westchester daily, so I cover some ground....
Edited by Navig8r
AMC RULES
Sure, will send in a PM.
  • Thanks 1
