Schrec050584 2 #1 Posted November 17, 2018 Can anyone help. I have a model 79360 42" single stage snow thrower. I need the chain and also the half moon key that the drive gear under the plastic cover on left back of the blower. Share this post Link to post Share on other sites
Ed Kennell 39,426 #2 Posted November 17, 2018 to the Tractor Supply Store has the chain and the woodruff key. 2 Share this post Link to post Share on other sites
Schrec050584 2 #3 Posted November 18, 2018 Is it a certain size and what size chain? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,152 #4 Posted November 18, 2018 Will guess the 6416 chain is #40 but best to take the old one with you to match it up for width and pitch. Usually comes in 10 foot lengths at considerable savings. They sometimes include a master link but good idea to pick up an extra plus a 1/2 link. When you instal the U-shaped keeper do so that the natural chain direction of travel will keep the keeper on. The 937089 key is a Woodruff #9. 3/16" x 3/4". The actual length of the key is .704" Garry 1 1 Share this post Link to post Share on other sites
Ed Kennell 39,426 #5 Posted November 18, 2018 I believe it is size 40 chain. Take your sprocket along and make sure the chain fits the teeth when you wrap it totally around the sprocket. Use a piece of tape to measure the length of chain that you need for your blower. TSC sells the chain by the foot. Buy enough chain and a connector link. Make sure the tensioning idler sprocket or block is loosened when you install and cut the chain to the correct length. The chain will stretch with use, and you will have to tighten it with the idler sprocket or bloc. OOps, I see Garry has answered your question. Thanks Garry 1 Share this post Link to post Share on other sites
peter lena 8,931 #6 Posted November 18, 2018 don't forget to use STAR WASHERS on the chain adjustment slot on side of thrower, they will not slide or loosen up. also try and use chain and cable spray , regularly on that gear and chain setup, its made for that . pete Share this post Link to post Share on other sites
Schrec050584 2 #7 Posted November 18, 2018 Peter what star washers and where is the adjustment. I appreciate all the imput everyone. 1 Share this post Link to post Share on other sites
peter lena 8,931 #8 Posted November 18, 2018 https://www.webstaurantstore.com/ts-014200-45-easy-install-stainless-steel-swivel-to-rigid-lock-washer/51001420045.html?utm_source=Google&utm_medium=cpc&utm_campaign=GoogleShopping&gclid=EAIaIQobChMIrtuh_tre3gIVDa_ICh2T4wbgEAQYBSABEgLqt_D_BwE star washers, are here, they have outside edge bite edges, to really set themselves into metal. looking at the thrower , chain auger drive is on right side, on outside of that , there is a horizontal slot with a bolt/nut to adjust the chain. its probably sloppy , snug it up , lubricate it. washers @ hardware store , pete 1 Share this post Link to post Share on other sites
Schrec050584 2 #9 Posted November 19, 2018 Which nut on the outside is it to tighten the chain? I cant see a slot. Is it the upper or lower one? Have a pic? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,152 #10 Posted November 19, 2018 You can see the adjuster slot in this picture - bottom sprocket. Garry Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #11 Posted November 19, 2018 Use this diagram it will help you with the adjuster nut, Jeff. Share this post Link to post Share on other sites
