FlirtationFarms 2 #1 Posted November 17, 2018 I have a workhorse transmission in a 1986 wheelhorse 414-8. There is a difference but will it mater? I put this transmission in because I was going to a tractor show and I needed it to work after mine had just broken. Will I brake anything else by doing this? Share this post Link to post Share on other sites
stevebo-(Moderator) 8,351 #2 Posted November 17, 2018 You have the 1” axle instead of the 1 1/8”. With a 14 hp pretty much running stock class the 1” will be fine 1 Share this post Link to post Share on other sites
953 nut 55,821 #3 Posted November 17, 2018 9 hours ago, FlirtationFarms said: Will I brake anything else If you try hard enough I guess you could brake it. In the drag racing community there is an adage the says you build the engine until the transmission breaks, then you build the transmission until the rear end breaks! 4 1 Share this post Link to post Share on other sites
FlirtationFarms 2 #4 Posted November 17, 2018 3 hours ago, 953 nut said: If you try hard enough I guess you could brake it. In the drag racing community there is an adage the says you build the engine until the transmission breaks, then you build the transmission until the rear end breaks! Thanks 1 Share this post Link to post Share on other sites
