dave647
310-8 brake pedal return stop
dave647
as near as i can tell, the return on the brake pedal is controlled by the floor pan. is this correct? IF SO CAN I USE A BUMPER PAD IN THAT LOCATION? I WILL USE A PAD THAT IS THE SAME AS THE ONE USED AT THE REAR FENDERS. thanks for any info. excuse the caps (i am not yelling) i hate computers
  • Haha 1
wallfish
It is not or should not be controlled by hitting the floor pan. You can adjust the linkage some as it seems like your pedal is returning back a little far. Of coarse it's not a problem if you just want to "bumper it" from rattling and the brake is actually working correctly.
Use the search box, upper right corner, and find the manual for your tractor in the files section. It should explain how to make the adjustments.
gwest_ca
Think I have had this happen. The pedal comes back way too far because the footboard where it is supposed to stop gets bent down. Bend it back up and you are good for another couple of years.
Garry
