953 nut 56,487 #1 Posted November 13, 2018 11-13-1898 Elmer Pond was born Wheel Horse started in Elmer Pond's garage in 1946. Mr. Pond started building two-wheel garden tractors using surplus parts. Within ten years, his business had become very successful and began to build a full line of lawn and garden tractors, in addition to riding lawn mowers. This is a story that starts out way before the brand name "Pond" or "Wheel Horse." It starts out with the name "Shaw." Elmer Pond and his associates, Glen Hielman and Harold Pond worked for many years for Shaw making tractors. These tractors were produced out of motorcycle and automotive parts and were made for the bigger gardens and small orchards. After a while the three men decided to build their own tractor and go into business for themselves. Harold Pond had worked for Shaw since the 1920’s and decided that he would make a tractor known as the Speedx Model "B," and Pond garden tractor in 1938, which would be one of the first four-, wheeled garden tractors. Glen Hielman would make the "Garden Master" in 1952. After World War II, Elmer Pond took the advantage, as did the other two men, to make a smaller lawn tractor that could do the work of a garden tractor and a lawn tractor. People who had a small garden didn’t need or want a big tractor for the small jobs they had to do, so they depended on these men for their garden needs. Another reason smaller garden tractors became very popular was that these tractors were rather inexpensive, so even the typical family could own one of these tractor and maintain it for a low cost. Many of these tractors were made from small air-cooled engines, drive systems, axles, wheels, tires, and other various parts that could be found. The framework was made from pieces of angle or channel iron. Elmer Pond started production in 1946 in his two-car garage in South Bend, Indiana. These tractors were made from crude parts that could be found. He produced a two-wheeled tractor that was self-propelled, which was sold under the Pond name. Pond made these for nine years, known as the "Walk- Away's " because the design of the tractor. After the first year of production Pond decided to make a four- wheel tractor. This tractor was made from crude parts such as a model "A" transmission, an 8.3 Wisconsin engine, Tiller steering, and much channel iron. The tractor was known as the Ride-Away Senior and was mainly for garden use. This model of the Senior was designed without a hood for easy serviceability. In 1948, Major changes occurred to the business and the tractors. Cecil Pond, Elmer Pond’s son, joined his father to make a partnership that would last for a long time. The tractor they created gained a fiberglass hood, and a Ross steering gear. The Ride-Away Sr. was produced for another seven years with small variations. In 1955, Pond started to make three different tractors, including the Walk-Away, Ride-Away Sr., and introducing the Ride-Away Jr. This new tractor would have a 2.5 HP Briggs and Stratton, or a 3.6 HP Clinton engine that would satisfy the needs of the typical house hold. The small tractor had a unique engine mount located between the driver’s legs and a belt driven transmission, "Variable speed." Pond made it so that you could put many different attachments on these tractors by welding brackets on them or making simple attachments that sold under their names. By the end of 1957, Pond had exceeded $1,000,000 dollars in sales. During the next years, a change would happen to the tractors; they would stop producing the Sr. after the first year of selling the little Jr.'s. They also changed the steering wheel on the smaller tractors from cast-iron to a larger diameter steering wheel. A new model was produced in 1958, which included a three-speed transmission. This transmission is called the Uni-Drive transmission that Elmer Pond designed in 60 days. The Rj-58 was the name of the model and it included one of the following engines: the Clinton B-1290 was used along with the Kohler k-90 were used to drive the small tractor. The Rj-35 had a Clinton B-1200 was used to drive the belts to the gearbox to move the tractor. They also put a Briggs 2.5 HP engine, which made the model of the tractor the RJ-25. The attachments remained the same for the RJ series. From 1956-1957 wheel horse changed the color of the wheels. They changed them from black into an almond color. The demand for these little tractors grew so much by the end of 1959 that they couldn’t keep up with production. But, they still made over 4,500,000 dollars. In 1960 there were significant style changes. However, the engine location immediately in front of the operator and the 12-inch wheels stayed the same. Two models of tractors were introduced this year: the model 400, with a four-horse power Kohler engine and the model 550, with a 5.5 horse power Lauson engine. These two models were known as the "Suburban" tractors. During this year the company obtained property on 515 W. Ireland Road. South Bend, Indiana. This plant was constructed in 1961 and occupied in July and August concluding of the 1961 production year. These two successful models continued until the next year known as the 401, 551,701. This was the first year for the front mounted engine tractor. Wheel Horse made the 701 with a 7-horse power Kohler engine. A change in transmission from two side plates and a piece of cast to two pieces of molded cast that went together instead of three. All models remained the same from 1961 to 1962 with all having the front mounted engine. The models were called the 502, 552, and the 702 the hood was a major appearance change. In 1961 they had an aluminum gas tank and a unique hood shape with a slotted grill. Also this year Wheel Horse produced the 32R and 32E, which were named Lawn Ranger, and they were made for lawn care only and removal of snow. In 1963 all five models remained the same as in 1962. The new product introductions for 1963 were the model 953 tractor and the model RM 483 48-inch mower. The garden tractor had a 9.6 horse power engine and 15-inch wheels with 27-inch tires. The model 953 unit was the first of the "large frame" garden tractors offered by Wheel Horse. In 1964, an 8-horse power Kohler engine replaced the 7-hp engine in the model 854. The model 953 was updated to the model 1054. At the beginning of the model year Wheel Horse acquired the REO product line from Motor Wheel Co. This product line consisted of walk behind rotary power mowers and walk behind snow throwers. Walk behind tillers and a rear-engine-riding mower also acquired but were closed out and never put into production. Sales volume in this year exceeded 11 million dollars. 1965 was the first year for the infinite speed shift system to the industry. A Stundstrand hydrogear unit was added to the Wheel Horse "Uni-Drive" transaxle. Tractors using the automatic shift were called "Wheel-a-Matic" tractors. The new "Wheel-a-Matic" models were the 875 and the 1075. Other products introduced in 1965 included a new 42-inch rotary mower attachment, a "REO-Matic" rear engine riding mower designed by Wheel Horse, and a completely revised line of REO power lawn mowers. The 1966 model products were unchanged from 1965 except for the addition of a 12 horsepower, automatic shift garden tractor and a 36-inch tiller (RT-366). The large frame model 1054A tractor was dropped from the line. Sales volume in this year reached 19 million dollars. 1967 saw the emergence of the "six speed" tractors. A Hi-Lo range was added the "Uni-Drive" transaxle to obtain six speeds forward and two reverse speeds. The new six speed tractors were the 867, 1067, and the1267. The Lawn Ranger models L-107 and the L-157; "Short Frame" models 607, 657, 877; and "Long Frame" models 1057, 1077, and 1277 were also in the 1967 line. In 1968 Wheel Horse began the model naming process, Commando (3 speed), Raider (6 speed), Charger (automatic), and the Electro (Automatic with electric clutch). They also had full-length footrest; and "B" section drive belts were added to the long frame tractors. Also in 1968 there was a "500" special tractor that was sold to dealers in Indiana, Illinois and Ohio in a promotional event tied into the Indianapolis 500-mile race. In 1969 they initiated more new products than any other year in Wheel Horse history. Wheel Horse’s first 14 horsepower tractor called the GT-14 was at the top of the line. It was a large frame tractor with 27x 9.50-15-rear tires. A new series of tractors using vertical shaft engines and a new vertical input transaxle was introduced. The spring of 1969 saw the opening of a new plant in Geel, Belgium called Amnor N. V. Wheel Horse lawn tractors are known for their standardization across the years. In the 1986, Wheel Horse was purchased by Toro. Toro continued to build garden tractors using the Wheel Horse name until 2007. 11 8 1 Share this post Link to post Share on other sites
Pullstart 63,331 #2 Posted November 13, 2018 Wow, good read! Happy Birthday @elmer pond! 1 Share this post Link to post Share on other sites
LengerichKA88 1,883 #3 Posted November 13, 2018 I didn’t know they’d made one that tied into the Indy 500.... in Indianapolis they don’t air the race (🙄🤷🏻♂️) on TV, so we always had to listen to it on the radio. The cool thing about where I grew up, it sounded like we were listening to the race in stereo because we could hear the track from our house. One of those would be a double whammy find for a Hoosier in Indy lol, bet it would be well received on Carb Day our at the camp grounds 😂. Happy birthday Elmer! 3 Share this post Link to post Share on other sites
Blackhood Bill 721 #4 Posted November 13, 2018 There are several 500's on Facebook. My friend funds and space just don't allowed to pick one up since I'm in Indiana just about 1 hr north I definitely would get one. Who knows maybe one day it will be in the cards. YES VERY INTERESTING READING. HAPPY BIRTHDAY 2 1 Share this post Link to post Share on other sites
Tankman 3,520 #5 Posted November 13, 2018 Thanks for the post! Great man, Happy B-Day Elmer! 7 Share this post Link to post Share on other sites
Razorback 1,048 #6 Posted November 13, 2018 (edited) Happy birthday, and thank you for 2 awesome lines of garden tractors! (Glad to be fortunate to now have a Speedex 1631 AND my recently-acquired Wheel Horse C160! Good examples from both families!) Edited November 13, 2018 by Razorback 2 6 Share this post Link to post Share on other sites
KC9KAS 4,741 #7 Posted November 13, 2018 Mr. Elmer Pond (R.I.P.), and for the Wheel Horse line of lawn & garden tractors! 2 1 Share this post Link to post Share on other sites
PeacemakerJack 10,742 #8 Posted November 13, 2018 A big to a man who saw the benefit of capitalism, worked hard, and fully realized the American Dream from a dirt poor existence in the Great Depression era to a country and world leading market segment multimillion dollar company in the 1960’s. May more American entrepreneurs be able to follow the footsteps of Elmer Pond 8 Share this post Link to post Share on other sites
Rp.wh 1,103 #9 Posted November 13, 2018 it was a great read. And thanks for the enjoyment of this tractors and the group that has came together and the family memories that they will give us. Thanks again and happy birthday Elmer Pond! 2 Share this post Link to post Share on other sites
ztnoo 2,298 #10 Posted November 13, 2018 120 years. That's a BIG number. Somewhat akin to Elmer Pond's forward thinking. 1 Share this post Link to post Share on other sites
JCM 9,843 #11 Posted November 14, 2018 Thank you for the history lesson andThank you Elmer for the best garden tractor ever built, I have enjoyed and appreciated them for the last 29 years.Rest in peace my brother. 1 Share this post Link to post Share on other sites
Herder 2,354 #12 Posted November 15, 2018 Thank you 953. I did not know the hole history. I even printed it out. Going to keep it with my WH manuals. 1 1 Share this post Link to post Share on other sites
ZXT 2,401 #13 Posted November 19, 2018 Very good read and history lesson! It's neat to know some of the history on WH's. I didn't know anything about their creation until now! The Indy 500 model would be a cool tractor to have. 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #14 Posted January 1, 2021 (edited) A picture with his wife Anne Marie They lost there oldest child Eugene L Pond in 1944 at an age of 22. Anna Marie Berends Pond past a way in 1971. He passed in 1977. Edited January 1, 2021 by Maxwell-8 1 Share this post Link to post Share on other sites
rjg854 11,654 #15 Posted January 1, 2021 I'm sure glad he was born and did what he did with his life. His legacy will live on with us as long as his tractors continue on and with the way they were built, that's gonna be a very long time. Share this post Link to post Share on other sites
Wheelhorse#1 1,736 #16 Posted January 3, 2021 Smart man.Good read. No doubt made to last,back when quality ,craftsmanship with longevity in mind. Unlike in today’s world.where everything is plastic cheap and throw away. Happy B-Day Mr Pond Share this post Link to post Share on other sites
