Horseoholic
Rear tiller install
Horseoholic
Hey all, I have a question about installing a rear mounted tiller on my 1971charger 12 automatic. I would like to get a tiller to install maybe next year but I don't know what all is needed to hook it up, I never had an attachment for any of my tractors except for a mower deck and want to know what parts is needed for installing. Any information is greatly appreciated.IMG_20181111_142520.jpg.34be0d37b3716cafb8802007c36b1e2d.jpg
gwest_ca
You will find this file handy. The A in D&A is the attachment list for your tractor.
The tiller in 1971 was model 7-1211 on page 2 and continued on page 3. Those other models are recent but the list leaves out many models. Here they are in the order they were produced.
Tiller DNA
1966 model RT-366 replaced by
1967 model RT-367
1968-1973 model 7-1211 ----------from here
1973-1974 model 7-1251
1975 model 7-1252
1976 model 67-36TL01
1977 model 77-36TL01
1977 model 77-36TL02
1978 model 87-36TL01
1979 model 97-36TL01
1980-1982 model 07-36TL01
1983-1985 model 07-36TL02
1986-1989 model 07-36TL03
1990-1991 model 07-36TL04
1992 model 07-36TL05
1993-2001 2003-2007 model 79370 ----------to here should all work.
If you check the parts lists for all models they show everything required.
We likely have most of the operator manuals also which helps with installation.
Garry
pfrederi
Having an Electric PTO make sure your tiller is up in the air and not clogged up with sod before you engage the PTO..Also I would throttle down when engaging to reduce the shock to the belt, idler pulleys, and tension spring.  The belts are expensive.
WildHorses
No automatic alt text available.No automatic alt text available.
  • Excellent 2
