Old Iron
Stack style mufflers
Old Iron
Where are you guys buying stack mufflers like this one and what are the different sizes available?
pfrederi
If you have a Tractor Supply Store (TSC) nearby the usually have some tractor mufflers in stock...Cubs used small diameter mufflers
big mike
I use a street 45,a pipe nipple long enough to get it out away from the hood and a Cub muffler with a piece of tube welded on to extend it.The tube I use is a chain link fence line post.....cheap,easy to get and just the right size.
pfrederi
I should have added that when you are buying the muffler get a rain cap. They look cool and if your horse is every accidentally left outside in the rain you will avoid water in the engine problems.
TT
I used the IH-1 Farmall Cub muffler from TSC, etc.
A few pieces of black pipe, two elbows, and a B&S band clamp makes for a decent vertical exhaust.
I also tack-welded all threaded joints so it couldn't spin.
NOTE: A "working" tractor should have a support brace installed.
Bill
I Personally use pipe from TSC with mandrel bends, And on my d-250 I also use the same muffler that TT use's, I don't like using the Black pipe fittings because to me they look like a plumbing job that went wrong :thumbs:
bustedglass
Got mine from Tractor Supply Store. They have various sizes, that you should be able to make fit on just about anything. Mine shown in my avatar is for a Farmall Cub.
HORSEOFCOURSE
are these engines alot quieter with these taller mufflers compared to the stock style? i used to be a fan of loud and proud but i am leaning aways from that now that i am sick of hearing stuff long after i have shut i down. :thumbs:
Coadster32
Bill, are you going to bring your two stack Wheel Horse next Sunday?? I'd like to ckeck it out. :thumbs:
jerrell
:thumbs: Bill that is exactly the style i want on my GT 1800 LP, having trouble finding the connections that bolt to the engine then will make stacks just like you have there...good job.. :whistle:
and those rain caps looks better than a coke or beer can to keep the rain out...
WHC-125
In my opinion I like Bill's the best. 1. Because it sounds awesome. 2. Beacuse it looks cool. 3. Because I got to drive it :thumbs: Did I mention Bill was doing wheelies with it :whistle:
oldandred
now this is a horse with a differenty engine
Tractors
A piece of exhaust pipe from tractor trailer, some tubing and a little fabricating I made this one for my Horse. Has great tone. Not as tall as Farmall Cub or Cub Cadet mufflers.
Jim
Tractors
Installed
WHC-125
Installed
Isnt that one off a Cub Cadet :thumbs:
Bill
Yes I'm going to be taking this one with me, I'll be meeting you at Chris's house in the morning
Buzz
Not to change the subject, but WHAT THE HECK DID YOU DO TO YOUR STEERING WHEEL???? :thumbs:
Teddy da Bear
HorseOfCourse...I hope it isn't "voices".... :thumbs:
Tractors.....that is a sharp looking tractor.....even like the white deck.
I think they sound a little deeper in bass...not the higher pitched sound of
the stock muffler.
Tractors
WHC,
No, It's the one seen in pieces in the frame above before welding it up.
Jim
Tractors
The Cub Cadet Muffler Has a rounded top and bottom.
Attached Image (Click thumbnail to expand)
Tractors
The Farmall Cub has longer tubes both ends and the body is also longer.
Jim
Old Iron
Thanks Guys. I have a bunch of great ideas now!! :omg: I post pics once I get something installed.
Old Iron
Here's what I ended up with. Thanks for the info. Good ol' TSC!!
gwgdog66
How does it sound??
TT
How does it sound??
Here's what mine sounds like on a K-321:
