Pullstart
Allis D-14 value?
Pullstart
I found an AC D-14 with a backhoe, bucket and forks.  I need to dig a pond and have nothing to dig with.  I feel like a loader/hoe is the most versatile tool for the job.
any insight on what something like this would be worth?  It has had recent head work and runs good.  There are some small leaks, nothing I couldn’t fix.
It’s been stored inside and comes with manuals.
953 nut
According to Machinery Pete the value of the tractor alone would be $ 3,000 to $ 4,000. One thing is sure, once you finish your project it wouldn't be too hard to sell, may even make a little money if you can buy it right.
:wwp:
https://www.machinerypete.com/listings/tractors/under-40-hp/allis-chalmers/d14
Pullstart
That helps a ton Richard, thanks!  I normally use some of my snow plow income to build my machinery base and invest in something that would deem useful around the house or on potential job sites.  When checks roll in and cover my expenses, I might just look this guy up for a test drive...
bds1984
Are you sure you wouldn't need an excavator for digging a pond?  I'm mostly familiar with a JD 310 and 510s and it'd be slow, slow digging a pond with them!  Do you have a dozer at all?
Pullstart
I don’t have any real digging equipment, just a dump truck and dump trailer.  I am not worried about the time it will take, if it’s a versitile tool all around.  I’ll be able to dig and scoop with one piece of equipment, and I don’t mind a little site prep making a safe trail into the bottom of the hole.  My goal is to have open water year round, but maybe dig during dry or frozen season to prevent sinking too much.
As you can see, I have no elevation change in my property, so water chooses to fill my sump crock all the time.  The pump never quits running through the year, sometimes it is only “off cycle” for 30 seconds before the crock is full.
953 nut
:woohoo:      That is a serious bucket on the backhoe. You can move a lot of fill without even moving, just fill the dump truck and transfer the load.
Sounds like you may have a spring near by. If you can divert it to the pond you will have good fresh water to stock with fish. May even want to make a sand beach for the girls.
Pullstart
I was thinking about stocking it.  I am not sure if it’s a spring, or the fact that all the surrounding fields have been tiled towards me.  Ideally in the long run, I’d build a windmill with a water pump to keep the water open year round for some tilapia or the like.  My Aunt and Uncle had a stocked pond when I was growing up, just a Honda 110 three wheeler ride away.  Good times, it wasn’t fishin’ it was catchin’!
Chris G
D-15s are a good machine. We had a d-15 and a d-19 when I was younger on the farm. Both were pretty tough. Pulled a lot of tree stumps with the d-15.
dells68
Talk to @ACman Kev.  His family was in the AC business for many years and he would be a good source of information and might even have a few good leads on good deals for you.
Pullstart
Ok, now on to another question, or comparison?  A 1953 Ford NAA came up too, with a backhoe and loader bucket.  It hasn’t run in 2 years, but is about half the asking price.  “Ran fine when parked”.  I imagine I could breath life into it, is it of any comparison with the AC.
953 nut
I would be skeptical of anything I can't drive unless it is nearly free. The 8N is a great light weight tractor but like any other tractor the maintenance (or lack thereof) is key. Most of them were gas engines and parts are easy to come by. You could take a battery and starter fluid with you to see if it will at least try to run. If it is a diesel the fuel system could cost a small fortune to get right. Lots of hydraulic hoses that may become a problem when pressure is applied.  Don't know about this. You are a good enough mechanic to figure it out.
“Ran fine when parked”  They always say that!    :ychain:     Is that why it hasn't been used in two years?             :scared-yipes:
Pullstart
Looking at tractordata, they are comparable size and power wise, and it’s much more affordable!  I sent the owner a few questions... we’ll see!
1995 520H+96+97
The NAA is going to be difficult to get on and off. 9N or 2N front wheel
ebinmaine
I agree with the loader/backhoe being a good versatile choice.
Please be careful here.
Birds and other animals can and will move babies or eggs from your pond to another and wreak havoc on surrounding ecosystems.
It may be better to stick with local native species.
Check with your local authorities as to what live fish are legal for an outside water.
Here in Maine they are extremely strict about enforcement of the fisheries rules and regulations and they definitely do apply to private waters.
Pullstart
I was wondering where the “point of access” was...  I don’t understand that last sentence?
Good point about species selection, I’ll be sure to take up to local authorities when the time comes!  Right now we’re talking pipe dreams...
1995 520H+96+97
9N or 2N  are Ford tractors built 1939 to 1947. Naa came with different hub and wheel.
Pullstart
Ok, gotcha.  Thanks!
953 nut
Looks like a mid '50s Ford Jubilee, that is when they went from the flathead to overhead valves. Is the back hoe a home made unit?  Front end loader is probably a factory unit, I've seen them before and they always looked light duty to me, but they work and have held up well. They have a six volt positive ground electrical system, but you can use a twelve volt Chevy one wire alternator and twelve volt negative ground in place of the generator. The starter will turn in the correct direction, just a bit more briskly. I think I would want to attempt to get it running before pulling the trigger.
ohiofarmer
 I have a Ford 445.also a Bobcat 853 The tractor itself is an industrial unit with massively heavy front end knuckles as compared to a farm tractor.  Same with the bucket hydraulics and frame. Even with a heavier unit, they are pretty cumbersome to cut and move dirt just with one machine. If you were to dig that pond and have a second operator with a Bobcat with a toothed bucket to move the dirt, It would be done while you are thinking about it with just a Tractor/loader/backhoe.  Bobcats rent by the day or week and it would be worth it IMHO.  Bobcats on rubber tracks will really float over muddy conditions that you might encounter on your project
Edited by ohiofarmer
AMC RULES
How big is the "pond" going to be Kevin?
Might be more cost effective, and efficient...
to just rent the appropriate sized machine for the job...and be done with it.
Pullstart
According to the DEQ, I am ALLOWED up to 5 acres water and 1 acre open water year round.  I doubt it’ll be anywhere close to those dimensions.  I have a high water table and the drain tiles running to my crock constantly run at one pace or another.  I understand that I may never stop that, but to give the water a place to run away from the house is the ultimate goal.  Plus, a pond would be an added benefit to that deer population out back too.  I have an old F-350 dump truck to haul the dirt and have no urge to complete this in a weekend...  but to make decent and steady progress.  My issue with renting on a timeline, is I doubt I’ll accomplish what I want before my time runs out.  If I could find someone who would rent me equipment on an engine hours basis, that might work out.  There are a couple people around here that have larger backhoe/loaders and I might just knock on a door some day to inquire.
LengerichKA88
Here in Indiana, the DNR will stock your body of water for free, the catch is that you have to allow public fishing for two years. The thing about that is; you don’t have to tell the public. Might give your local DNR a call and see if they have a similar program.
oliver2-44
If the D15 is a factory loader backhoe industrial unit it will have a heavier front axle, spindles, etc than the comparable farm tractor. It might even have a forward/reverse shuttle transmission which is extremely handy when using the loader. The NAA is a good farm tractor with a good transmission.  We had one and pulled a moldboard plow with 2 18” bottoms. But I would sure look over the front end.  Also check the hydraulics for signs of water. Pitting in the cylinders is usually to deep to hone out
My Oliver 2-44 is the industrial version of a 1067ish Oliver 550 farm tractor. Even it’s heavier front spindle vertical shafts have excessive wear and the heavier center pin also has some slop. It has power assist steering but is still a beast with a full loader bucket on soft ground
Sent from my Texas deer stand
Pullstart
And good luck hunting!
